Question about Microsoft Xbox 360 Console
360 video problem on HDTV
I just bought an xbox 360 and connected to my RCA HD-ready TV using the component video cable set to HDTV. The TV is 1280 x 1080i so I went into the display properties on the xbox dahsboard and set it to 1080i but then then the picture goes out. So I tried 720p and that didn't work either. The only resolution setting that works is 480p which I believe is the same as a standard definition TV. Am I doing something wrong? Do I have a lousy TV or is there something wrong with the xbox?
  • galileo102 Dec 31, 2007
    The TV is a 52" CRT rear-projection model #D52130, about six years old. I'll try swapping TVs and xboxs and see what happens as you suggested. The instruction manual is here: Page 63 gives the rest of the specs for the TV. Thanks for your help on this.
  • 85 Answers
I need a little bit more info on the TV its an RCA what?,
In the mean time what you could try is finding someone with a HD tv and trying it out at there house so that you can single out if it is your system or the TV. This will help alot you can also try someone else's xbox 360 at your house on your tv to see if it is your AV cable / xbox360.
Posted on Dec 31, 2007
I recently got a 51h83 toshiba tv. When i try to hook up my xbox 360 with the hd component cables in the back i get sound but no video. Please help.
Nov 16, 2016 | Toshiba 51H83 51" Rear Projection...
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
and for the video reset about halfway down the page:
Mar 30, 2011 | Video Game Consoles & Games
I was having trouble with my component AV cable. I went to purchase a new cable, HDAV component cable and connected the xbox. I had an image for a short time and now do not. Please help!
your HD settings may be too high, go to "display settings and change them, if your not on an HD tv, change the output to "TV" on the AV cord where it connects to your xbox, if you Are on an HD tv make sure the output is set to "HDTV" on the AV cord where it connects to your xbox, there is a little switch on the side that slides left to right
Jan 16, 2010 | Microsoft Xbox 360 Elite Console
No sound on Technika HD TV when using my Xbox using HDTV cable
i cant get soun when playin my xbox 360 on my technika tv. how do i obtain sound?
Jan 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 hdtv connection help!!!
Yes, you will need HDTV compatible AV cables.
Jun 25, 2009 | Microsoft Xbox 360 Console
Just set up my new xbox 360. My TV is not HD and I have an antenna and hd converter box. Which does not seem to connect to the xbox console in any way. It seems like my wireless device linked up but I...
I'm not sure exactly what the problem might be, but if you try turning off the x-box and looking at the back, the A/V cables that come out of the back (shaped like a trapezoid where you plug it in) and they should be plugged into your TV.
If your TV uses the Red, White, and Yellow cable side, make sure the switch on the other end of the cable where it plugs into the back of the x-box is switched to "TV".
If your TV has component input "Red, Blue, and Green" make sure you switch it to "HDTV" and you'll also have to connect the red and white (left and right) audio cables.
Your HDTV digital tuner/antenna probably won't be the place to connect them.
If you do not have either cable setups on the back of your TV, you may have to go to an electronics store and purchase an A/V converter box or connector. They are not too expensive.
If you have a little extra cash to spend, I'd recommend getting a decent size LCD flat panel HDTV. Just make sure you NEVER buy a PLASMA screen to play VIDEO GAMES on (video games will destroy the screen and leave you with burn-in or ghosting). Although they are nice for movies and slightly cheaper.
I hope I could help you.
Jan 06, 2009 | Microsoft Xbox 360 Console
RCA D52130 52 in. Won't Display High Def
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Jan 21, 2008 | Microsoft Xbox 360 Console
Xbox component output causes "epileptic" flickering
x box 1 on a hdtv r u sure , or do u mean the 360?
Sep 13, 2007 | Microsoft Xbox Console
HDTV Problem
there shouldnt be a problem with the cable, if you use the component leads then you will not need to use the s video cable for video incase that is what you are doing, component only uses 5 connectors and the switch should be set at HDTV not tv and the tv set at component Use the following colours into your tv:- Green, Blue, Red and the audio red and white, you do not need the yellow or the s video plugs. Then select the 1080i when in the component setings on your tv and do the same in the dashboard settings
Jul 01, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
93 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
