Question about SanDisk Sansa e260 MP3 Player
No USB mode in settings / Coverter says no available player
My Snasa e260 does not have a usb mode in the sttings and also when i hook my sansa to the usb my converter says that there is no available player. I need help please because i really like my sansa but i can put the videos on my player but they won't show up.
  • 27 Answers
First of all. For the video issue. You may not be putting the vidoes in the right spot, where the player searches for them. Or if you are, in the right format. The e260 comes with a CD which contains a PDF manual and a utility for putting vidoes on the e260. If you arent using the utility that came with the e260 you wont get the vidoes to work because they will either be in the wrong format or spot. As the folder which they are supposed to go into is hidden, you must ask windows or your os to show hidden files/folders to manually insert the videos. As for your USB problem, Turn on the player and press the power button breifly to return the the modesd/welcome screen. Scroll through until you see settings and hit the enter button [The button inbetween the scroller] Then use the blue scroller to scroll down through the entire list until you see a setting called USB Mode. Hit enter again and in most cases select MSC. This should fix your problem. If it doesnt, attempt at updating the frimware of the player.
Posted on Jan 01, 2008
SOURCE:
Trying to add 4 GB microSDHC card to sandisk sansa e260. connect e260 to computer via USB. insert micro card. computer does not recognize microcard. why?
The player automatically connects to the computer in Media Transfer Protocol mode (MTP mode).
For accessing the microSD card in the player, the USB connection in the player has to be set to MSC mode, see:
http://kb.sandisk.com/app/answers/detail/a_id/167
How to change USB mode for the e200 series, proceed as next:
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
Manuals for the e200 series:
version 1:
http://mp3support.sandisk.com/downloads/um/e200v1_userguide_en.pdf
version 2:
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
version R, Rhapsody:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Nov 21, 2009 | SanDisk Sansa e260 MP3 Player
No USB mode on my sansa e260
I think this is what you are asking. Forgive me if I didn't understand the question correctly.
Switch on the mp3 player. Select "Settings", scroll to "USB Mode" and make sure that "MSC", not "MTP" is selected.
When you next plug in the USB connector, your PC should recognize the Sansa as a standard USB device.
Apr 07, 2009 | SanDisk Sansa e260 MP3 Player
I have Windows Vista and it says that it can't support the sansa e260
I would place the e260 in MSC mode first, as Vista should support this Sansa.
Unplug the player, then from the e260 do the following:
go to Settings, then choose System Settings then USB Mode & select MSC. Next, connect the E260, Vista should now see the player properly.
Mar 19, 2009 | SanDisk Sansa e260 MP3 Player
Sansa E260 - I don't have USB Mode on my settings
Go look under Menu > Settings again. Either go UP two choices or down eleven choices and there it is.
Dec 23, 2008 | SanDisk Sansa e260 MP3 Player
No usb mode settings
Depends on the firmware you have on your sansa you may not have that option available..what you need to do is to update the firmware and then you will have it..I hope that helps
Please rate accordingly
Thank you
Computerrep
Oct 07, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
which version of windows you have ?
Dec 27, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Dec 27, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
