Question about Lite On LH-20A1H DVD RW Dual Layer Burner
Error 41 cannot locate device
Thanks in advance for your help. I installed a new liteon dvd drive and can't get it to work, According to the device manager, the driver is installed yet it cannot locate the device. Any help would be appreciated.
  • 1 more comment
  • 2thdocm3 Jan 05, 2008
    I checked the diskmgmt and the drive was not listed. I appreciate your help
  • 2thdocm3 Jan 06, 2008
    Yes it is using a sata cable for the data. The drive that it replaced was using the other type of connection.
  • DeidreDee Jan 08, 2008
    The name for the drive is not DVD/RW as it was in the past. It now says that it is a cd rom, and doesn't acknowledge my dvd's in any way.
    Please help me.
    I am using WindowsXP OS.
    Novelist:
  • 167 Answers
Is the drive appearing in My computererror 41 cannot locate device - 4.gif with a drive letter?
If it isn't:
1. click Start, point to Run, type diskmgmt.msc, and then click OK
2. If you see your drive listed without a letter, right click on it and assign it a new drive letter
Posted on Jan 04, 2008
  • Steve Stonebraker
    Steve Stonebraker Jan 05, 2008
    Is this drive using SATA cables? If not you need to set up the drive as either a "MASTER" or "SLAVE" in your CMOS
  • Steve Stonebraker
    Steve Stonebraker Jan 06, 2008
    Try plugging it in to a different SATA port on your computer. Can you open and close the tray? Is it detected when the computer is first booting?
    See if you can try it on a friends computer and check your CMOS to make sure your SATA connections are enabled.
    If none of that works RMA it (Return to Manufacturer)
The drive is not being seen in windows 7
Is This recently installed drive? It could be missing drivers. click on start then right-click computer, and click properties, then on device manager a new window should pop up with a list of devices under cd/dvd rom drives check to see if your device is listed.
Jun 02, 2011 | Lite On LITEON DH16D3P-04 16X IDE DVD ROM...
Computer comes up with a code 41 error, can't play CD/DVDs music or downloads
This error comes because of cd/dvd registry changes. For that you need to delete some keys with below method.then this error will be fixed. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Let me know if you need further assistance. Thanks for using FixYa
Jul 10, 2010 | Lite On LiteOn 16X/40X ATAPI DVD BLACK ROM...
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
May 04, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Code 41
This error occurs when Windows does not detect a non-Plug and Play device.If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device. Hope this helps
Feb 16, 2008 | LG GSA 4163B DVD±RW Dual Layer Burner
Dvd writter is not working
hey john,
do you have a burning software installed? you can download nero express @ majorgeeks.com
you mention that your friend gave it to you? was it working fine before? its easy to set up your new dvd writer whenever you have already installed a burning software like nero. well, you can also try clone dvd. it works very well too.
and also check for firmware upgrades for your dvd writer...you can find it here...
http://drivers.softpedia.com/get/FIRMWARE/Lite-On/LiteOn-DVD-JLMS-XJHD166S-firmware-101.shtml
hope this hepls
Jan 24, 2008 | Lite On LiteOn 16x Black internal oem DVD...
My DVD-ROM cant read Video Files
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for DVD/CDROM Drives, click it and your DVD drive will appear. Right click on it and delete. Restart PC and windows will find your DVD drive again and install it. Try a dvd again and see if it is working, if not it's time to buy a new one i'm afraid, but they are very cheap to replace.
Mar 08, 2007 | Lite On LITEON DVD-ROM16X, 21600KB/sec...
Lite On LH-20A1H DVD RW Dual Layer Burner Logo
360 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
Alun Cox
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
