Question about Samsung CLP 300 Laser Printer
Black Toner Problem
Problem is that there is a white/blank stripe going down the left side of the page ONLY involving the black toner. In other words, if I print a page that is both black print and color images, just the black print is missing off the left side, color comes out fine on the left side. What is up with that???
  • 9 more comments
  • annwhiteside Dec 31, 2007
    I should add that black toner is full/new cartridge. And black toner everywhere else on the page is fine.....
  • nightfool Jan 03, 2008
    fine small black lines appear at left hand side of printed paper
  • Anonymous Jan 18, 2008
    I have the same problem - I have tried cleaning it and even put in a brand new blank ink - this did not help I still have a blank streak down the left side
  • bohey Jan 27, 2008
    Exactly the same problem. This started before toner replacement and is still happening despite buying new genuine cartridge. Every other colour works fine. Stumped.
  • Anonymous Feb 06, 2008
    All else applies. The only difference is that I have similar streaks down the page, about 4, where the print is faded.
    1. Changed Black ink cartridge. Shook to ensure redistribution of toner. 2. Cleaned m/c (Took out imaging unit and inspected drum visually), 3. cleaned orifice where Black cartridge goes.
    Problem persists.
  • Anonymous Feb 12, 2008
    I have the same streak down everything I print. Nothing seems to make it go away even replacing the items that Samsung tells you to.
  • Nickbo Mar 01, 2008
    I just brought a factory re-built CLP-300 and I have a double vertical white streak, I changed to a laser paper, shook and shook and shook again all
    of the toners, can't get rid of it.
  • John Peterson
    John Peterson Mar 07, 2008
    white line down center right of center. Shake canister
  • surferboy Apr 15, 2008
    our clp300 is 6 months old weve changed all toners, black was fine we left it, started to fade in and out weve had those lines, and prints fine in any colour but black, we have changed the black, all original toners, still problem persists, we are wondering the image unit, its done only 4000 reccommends 20000 tried tape over sensor, is there a chip needs soldering in i read somewhere.
  • Anonymous Mar 15, 2014
    All toners are brand new and authentic Xerox products. Black and white is fine, but color pritings always have a very precise blue or purple strip down the page, slightly left of center.
  • Anonymous Mar 28, 2014
    The left side of the printed page has has black marks on it
I had the same problem with my 4 month old Samsung. All of a sudden i had a missing black stripe down the left hand side after replacing the cyan toner with a refilled one!! So.....i uninstalled all the old drivers and downloaded and installed the latest ones.... replaced the cyan with a new genuine toner....removed the black toner, shook to redistribute and put it back.....checked the imaging unit for actual visual damage (there wasnt any!)..... then printed off 50 or so black n white documents. Eventually the 'stripe' dissapeared.
The colour toners were fine all the way through!
It worked for me, hope this helps!
Nigel
Posted on Feb 20, 2008
  • Nigel_S Apr 02, 2008
    Thought I'd fixed this problem, but it eventually came back! Had to change the Image Unit in the end....after less than 7000 images......not after the 20000 as it recommends in the manual!
    Nigel
  • 417 Answers
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Posted on Jan 20, 2008
How do I prevent my HP 1600 LaserJet from leaving a shadow of printing on the page?
Run 30-40 blank pages through it to take the image off the belt.
Go to Word or another WP program, call up a blank page and print it 30-40 times.
Mar 03, 2014 | HP LaserJet 1600 Printer
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
BLACK STRIP ON THE LEFT SIDE ON MY PAPER??? I HAVE A HP LASERJET 1022NW....WE HAVE CLEANED AND BLEW OUT THE PRINTER....STILL NO IMPROVEMENT....WHAT TO DO NEXT....
Run the 1/2 print test.
Put paper in the manual feed tray. Print a few pages of anything. As the paper gets about 3/4 of the way into the printer, open the cartridge door. Pull out the cartridge and look down at the paper. If it has the black stripe on the left side, replace the toner. In fact at this point, pick up the toner cartridge and gently swing the shutter open and look at the drum. You should be able to see a black stripe on it.
By the way, the toner hasn't been fused to the paper at this point. It will rub off on hands and clothes.
If the 1/2 test shows no stripe on the paper...replace the fuser.
Dec 01, 2010 | HP Office Equipment & Supplies
A vertical black stripe is printing on the left side of the page.
Have you tried replacing the toner cartridgein the printer? If you print a page then remove the toner cartridge, carefully open up the cover that covers the the drum on the toner cartrdige.You can often see a line that corresponds to the line printed on the page.
Oct 13, 2009 | HP LaserJet 1022n Printer
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Blank stripes on page left to right
If the blank stripes go up and down the page (vertical) then it sounds like the laser lens has simply got toner on it. remove the toner and photo conductor units. Look for the glass panel that covers the laser lens and simply wipe it off with a cloth. Some machines incorporate a lens wiping pad that can clean the lens without taking out the parts. I can not remember if the 1710 does or not.
Sep 06, 2007 | Samsung ML 1710 Laser Printer
Samsung CLP 300 Laser Printer Logo
748 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
