Question about Motorola Mobility ROKR E6 Smartphone
Not charging even though i changed the connector as well as my charger
  • 1 more comment
  • joanna123 Mar 09, 2008
    i put it on the charger for about an hour and the green light is still on and its not coming so please help me
  • airease16 Feb 15, 2009
    I put my motorokr for charging abt an 2 hours but it is not getting charge. also i tried to connect laptop and charge it but it is not getting detected.. Please tell me the solution
  • koushalkanna Feb 17, 2009
    ha same prob
    Sergeant:
  • 319 Answers
Perhaps a defective battery. I would go to the retailer that sold you the phone if it was recent and see if they can fix it for you. If not a battery is going to cost right around $80.
Posted on Dec 31, 2007
Batter is not charging, it is going to USB mode even when i connected to charger
Posted on Jan 02, 2008
My kindle is not charging
Is the device new or still under warranty? Is return to the store (RMA--"Return Merchandise Authorization"--through an online vendor) still possible? Extended warranty?
Is the charger (and outlet) OK? If you may attempt to use USB current from your PC/Laptop/etc., is that port workable and powered? Have you attempted an alternate method of charging? Is syncing then possible?
Chargers are not invulnerable--rarely, they sometimes overheat and die. After all, they're fabricated PRC items too--thus, even they may prove defective. (They're far less complex than a Kindle or phone, though--defective chargers thus prove quite rare.)
Chargers can't last indefinitely or through overly heavy use, either. (Chargers do tend to last longer than devices--failure proves quite rare!) Is the charger unusually hot after plug-in? (Such failure could prove a great danger to electronic devices. Very rarely, even fire or sparking is possible.) Is charger connection at the wall OK? (Is the outlet overloaded?)
Is it a "block" charger?: These may be replaced easily. Just get the connector and the Volts correct--with sufficient amperage (current). You don't need even to obtain the same brand and model as OEM--that which came originally with your charger. Online, amazon, Radio Shack, etc. may prove very helpful for such purposes.
Does the connector have sufficiently good contact through your Kindle's circuitry to its batteries? (Is the connection overly loose? Often, this occurs over time.)
Are you certain that the charging cable is OK? Does the connector in the Kindle need "doctoring" with a small tool, somehow? If the batteries are dead, it's likely possible to replace them.
It's possible that the device simply is dead (shorted-out)--power surge or fluctuation certainly are possible and likely culprits.
An extremely remote possibility is that the CPU or other key chipset is dead--even those prove useful for limited numbers of cycles. (Failure then implies quite extreme usage! Probably not!) It's not immortal!
Jun 28, 2014 | Amazon Kindle Wireless Reading Device
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
I have a gateway laptop which is not charging and even though i bought new chargers for it it still does not work i think the charging port is broken is there any possible way of fixing it without...
is the battery good? you could check and REFRESH it by discharging and recharging it many times in a row, as for the connector if it's directly soldered on the system board it can be replaced by an good experienced technician with the correct tools, if it is a connector with a peace of wire connected to the main board it is simpler for the user to change
Jan 12, 2011 | Computers & Internet
My laptop won't charge when plugged in...I changed the charger but still won't charge
Or:
Possible solutions:
Or:
Feb 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Oct 25, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
Phone will not take charge
I have the same problem with my phone i really don't know what is going on~!!!
Sep 03, 2008 | RIM BlackBerry Pearl 8100
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
Motorola Mobility ROKR E6 Smartphone Logo
202 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
