Question about Whirlpool Duet GHW9150P Front Load Washer
Washer need a drain pummp for washing machine and the cost
  • 1,314 Answers
Call your local parts store but what the reason you think you need a new pump yours may be just jammed and can be cleaned new pump around 103.00 in usa
Posted on Jan 01, 2008
How do i fix the E-13 error on my washing machine?
Hi Jerry,
I had a similar problem my LG would sometimes wash and other times I received a code(forgot the code it's been awhile)it wouldn't drain, I changed the pump etc.. I had the repairman at the house three times finally PC Richards replaced the washing machine. However after a week the same code came up. I and checked the voltage at the outlet and it read good. So, I checked the voltage while machine was running and I had 89V. I had a bad circuit breaker changed breaker problem solved! I hope this helps.
Nov 22, 2014 | Bosch Washing Machines
tub rubber is torn or cracked can be replaced but for cost u might buy a new washer
Nov 18, 2012 | Haier HLP23E Top Load Washer
Washing machine won't drain or spin.
You most likely need a new lid switch. It cost about $25 and you can purchase it at If the switch does click when you push it down then you probably have a sock or something in the drain pump:)
Nov 30, 2010 | Kenmore 24032\24036 Top Load Washer
Stop drain
the cost of a water pump is between $40 and, $60
but, you don't need one you only need to clear the obstruction in the pump impeller.
Jul 31, 2010 | Kenmore HE2 Plus Front Load Washer
Washer won't spin and drain, repair man said it was the transmission and should cost over 300 to fix it????
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 04, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor can find the part at It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Drain pump for washing machine
the pumps vary a lot but if in the uk, pump cost is about £25 and fitting about £40 but why do you need a pump?
Oct 22, 2008 | Zanussi IZ12 Front Load Washer
LG washer/dryer combo will not drain water
easy first unplug unit..take back remove phillips head the pump drain hose is the other side of the filter in front just take a pliers remove clamp,,replace hose..close unit plug back in
Aug 18, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Kenmore top loading washer not draining correctly
I had a similar problem---repairman took off the drain hose and found a curtain tie back stuck in the hose.(washed it two days before, wondered where it went) We were told that small items often float over the top of the tub and clog up the drain hose--he suggested using a small bag to wash socks, hankies ect. This problem cost us $75 to fix, but we could have done it ourselves. Good Luck Jen
Jun 12, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
