Cannot get my router to connect with my westell modem
I use SBC Global dsl. I am trying to hook up a router to it. It will not work. Belkin says I need to "bridge" them, but SBC says that's not the problem. Can anyone help? Neither of them offer support on the modem...
  • 107 Answers
You do not need to bridge your modem or router. I set up a linksys 4 port router with westel wire-speed and could web to both. You need to ensure that the modem is not handing out dhcp. you will also need to find out what the ip scheme is on the ethernet side of your modem. Most frequently it is 192.168.x.x You will then need to set up your router's WAN interface (so labeled) to be on the same scheme. Use DHCP on your router and you should be good to go.
I know I left out some details, but I don't want to type a book if you are comfortable digging on the internet or can take it from here.
Posted on Jan 04, 2008
I am trying to bridge a belkin n router to a d-link router
ok
the simplest way is to find some alternatives, here as some suggestions
now if you do want to attempt your solution do a few things first
first you do need to go into the belkin router's configuration page you can do this by:
  1. Open a web browser on the computer.
  2. In the address bar of the web browser, type http://192.168.2.1
  3. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
or if you set up a password can't remember it do this first
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/F5D8231-4/p/312/r_id/166
now.. you need to find out if both routers support bridging.. you need to look into both router's configuration page, I couldnt find you router's manual and you did not posted you dlink router's configuration.
if you do find bridging try the directions found here
post back if you have questions after reviewing each router's configuration.
now an alternative option is to
Dec 27, 2009 | Belkin (F5D8231-4) Wireless Router...
Connect router to playstation 3
You need to first plug the DSL modem into the router. log on to the router. Configure the router byusing the user name and password as supplied by your dsl provider. once the router connects to your dsl provider, you should be able to connect your playstation to the wireless network.
Jun 02, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin F5D8236-4 won't connect to the internet.
this issue mostly comes with dsl connections..
check whether the dsl modem is in bridge mode or pppoe method
if it is in bridge mode ask the isp vendor to change the modem into bridge mode which prompts you for username & password
try this it resolves the issue..
Apr 19, 2009 | Belkin (F5D5231-4) Router
ATT/SBC gateway router....
Take the ethernet cable from modem to PC and hook it into the router(modem to router)...run another ethernet cable from the router back to that PC(router to PC). All you machines should be fine then.
Jan 25, 2009 | 2wire 2700HG-B Router (2700HGB)
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
AT&T FastAccess DSL & D-Link not working for me
Yes D-link is compatible with DSL. What you need to do is call your ISP and have them bridge your DSL modem. Next you need to verify your username and password for your internet account. Next call d-link and have them help you change your router's setting to work with PPPoE connections.
Sep 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
Jan 05, 2008 | Computers & Internet
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
Computers & Internet Logo
316 people viewed this question
Alun Cox
David Payne
David Payne
