Question about Maytag Neptune MAH5500B Front Load Washer
MAH5500BWW model fuse blown
My fuse is blown on the motor control board. My question is can I just replace the fuse or do I have to replace the entire board? Obviously something caused the fuse to blow and I was wondering if this could have been caused by someone overloading the washer or if the fuse blowing was caused by a problem with the motor?
  • 1 more comment
  • Anonymous Mar 18, 2008
    Fuse blown on motor control board, also machine control board no longer works. I replaced the machine control board and am now in the process of getting the replacement for the motor control board.
  • Anonymous Mar 27, 2014
    The washer does not power-up and I have a live outlet. I suspect a blown fuse but do not know where to check.
  • Anonymous Mar 31, 2014
    I replaced the motor and motor control board. I still get the Lr fault. What else could be the problem?
    Scholar:
  • 79 Answers
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Posted on Jan 05, 2008
Ce code? on calypso washer
Hello there
The CE error stands for "Communications Error" and refers to a breakdown in communications between the machine controller and the motor controller. In practical terms, this problem is usually caused by a bad wire connection. The most common trouble spot is the quick disconnect at the motor connector-I've seen this problem a lot. Usually, if you just take off the connector and re-attach it, that clears it up... IF the appliance gods are grinning down upon you. But, you may not be so lucky and you may have to make a sacrifice in the temple of Appliantology to appease the appliance gods. Y'see, lots of other things can cause the CE error, too.
00110221.jpgFor ezzample, another common problem is a blown fuse on the motor controller board. Unfortunately, this ain't a trivial repair like re-seating the quick-disconnect plug at the motor connector. Nawsir, in this case, you gotta replace the entire motor controller board.
Now, you might delude yourself into thinking you're being all slick and clever by replacing just the fuse and save a wad of moola. Oh, my, but how I giggle and nearly wet myself when disheartened grasshoppers tell me of their folly in replacing the fuse on the motor control board only to
Mar 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
The circuit board has a 25 Amp slow blow fuse is blown
if your circuit board has a 25 amp fuse that a lot of power, like running the compressor.. you need to have a model and serial number for the unit , there is no generic control board , each manufacture has it's own design
Nov 15, 2009 | Refrigerators
MAH5500BWW "LR" Motor Control Board Failure
By the time you have finished mucking about it will likely cost you much more than it would to have a Techo come out to give you a quote for a few dollars to see if it is all worth it as regards your budget!
Oct 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will wash but not spin
Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
F1 fuse in Motor control board??
Dear wash boardn,
ngfam at you service!
need to clean your clothes????????
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Aug 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Nepture MAH5500BWW burned control board
ummmm, honestly ive never replaced just the board(im an authorized maytag servicer) so our replacements have always been new, and in this case the repair kit containing both board and motor. that being said, i cant see a reason as to why you couldnt relace just the board itself, ,Ireally never found the reason why the board would burn out, but, as far as repair kit im certain that they were trying to get all circuit boards and motors back to only one model, instead of having 5 or six different boards andmotors, this will bring them all to the most recent board and motor, never was an issue with themotor, jusat that you couldnt wire in the new board without the neew wiring. As long as its the same board i cant see why that wont work. as far as the "wax motor" that was a seperate issue burning out the Top control board, total seperate then your problem,., dont really see an issue with installing your "used board"
Apr 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mah5500bww
there is probably a Conversion kit for this.You HAVE TO REPLACE BOTH  motor/control board .Im here to help you if need my assistance.
Mar 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
2,478 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
