Hpna network card
I have a HPNA network card i got drom sbc a few years ago, it has worked flawlessly with my 2wire home portal 1000hw . recently the home portal quite, i purchased a belkin n wireles router useing it and the zyxel 600r modem that i got from earthlink i have set up and working properly, but cant seem to figure out how to get the hpna adapter to connect.the card i believe is a D-Link....any help?
    Genius:
  • 1,554 Answers
Have you set the router to broadcast in the backward compatible 802.11b mode also. it has a setting to do so.
Posted on Feb 25, 2008
I have a 2 wire home portal 1000HW. We recently had a power failure and the unit stopped working. I have checked the power supply with a vom and it is putting out the rated 6V. I have tried multiple...
Check your current rating on the OEM power supply.. I think your power supply needs 2 amps at 6 Volts. The cheap ones at radio shack are usually only 2 ma.
Jul 05, 2010 | 2wire HomePortal 1000HW DSL Modem and...
How do I get my brother 1250 printer to print automatically? It used to print automatically when I clicked on Print but now I have to go into the ?Print Options and click on the Hold button twice before...
2wire lost password reset 2wire dsl modem sbc 2wire router modem unlock 2wire 2wire 1701 hg ... 2wire homeportal 2wire 2700 2wire can't get ip address .... default 2wire password 2wire modem att white paper 2wire gateway ip address .... usb 2wire hpna linux working for 2wire wrt350n and 2wire modem ...
groups.google.com/group/alt.languages.catalan/.../a1f780eac37721f2
The 2Wire HomePortal is a wired solution that offers subscribers hassle-free, ... Cisco-Linksys EtherFast Cable/DSL Router with 4-Port 10/100 Switch ... 5.0 out of 5 stars I could not ask for anything better than this., December 17, 2006 ... I waisted my money. My tech guy said it was an older generation unit, ...
www.amazon.com › Video GamesMac GamesHardware
Jul 20, 2010 | Brother HL 1250 Laser Printer
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Can't connect to Xbox 360
reset it...look at back side of modem.....
and if it not works then contact your isp ...
Aug 18, 2017 | 2wire HomePortal 1100 Router...
I want to identify hardware.
Here is description of the unit , the installation guide and the user guide:
HomePortal 1000HW Router/Modem with Firewall & 1 Ethernet port, highpowered 400mw 802.11b wireless, USB, and HPNA.
2Wire HomePortal gateways include an array of the most common home networking technologies accommodating a variety of service provider and subscriber environments. Flexible networking options include high-powered 802.11g wireless, Ethernet, HomePNAv3, MoCA, and USB.
http://www.2wire.com/pages/pdfs/1000_series_Gateway_Install_Guide.pdf
http://www.2wire.com/pages/pdfs/2Wire_1000_User_Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 30, 2009 | 2wire HomePortal 1000HW DSL Modem and...
2wire homeportal 1000hw cannot find wireless address
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Feb 07, 2009 | 2wire HomePortal 1000HW DSL Modem and...
2wire 1800hg-- HomePNA stopped working
What you can do, is take the HPNA adapter from the back of the computer and plug the phone cable portion of it directly to the 1800hg's phone port. Since your 1800hg only has 1 phone port though it will not surf the internet, but this is a suggestion to try to make sure the inside wiring in your house is not bad. If you do this though your computer should say its connected, if it doesnt then it could be a driver issue or the phone cable in the HPNA adapter (try a new one then). If its the driver then try support.2wire.com for the regular usb drivers.
Jan 21, 2009 | 2wire HomePortal 1800HG Router...
Connect panasonic bl-ca10 cam to a 2wire home portal 1800g
Try using WEP instead of The WAP protocol.
It worked for me.............
Jul 06, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
