Samsung TXK2754 27" TV
Problem for Samsung TXK2754 27" TV
No Picture Has a bright horizontal line with off white & gray vertical bars
By winber on Dec 31, 2007
The tv has sound but no picture just a bright horizonal line 1/3 of the way from left side of tv and off white and grey vertical bars but not rolling. When I turn the tv on the green light in front blinks then goes out the tv tones and then you see the screen i was talking about.
Same Problem
Apr 06, 2008
-   My TV is 27 " and branded as SEARS Canada model 57-14367 but it is actually a JVC TV. For sometime I had a few gray horizontal lines running across the TV on about 2" top part of the screen but picture was ok for most part except that in the top part behind the gray lines it was somewhat distorted. Suddenly today, the screen has no picture but only a bright horizontal bar across the screen.
Can somebody inform what may be the problem and how to resolve it?
Thanks in advance.-   didasapa
Best Solution
posted on Feb 21, 2008
Very Helpful)
progrsys
Rank: Apprentice
Rating: 100%, 1 votes
The Problem Philips 27TS54 c101 27B800-7562 White horizontal line in the center of the screen. Color is present in the first half inch of the leftist corner of the horizontal line.
Audio is present and controllable. The green power led from a cold non plugged in state remains solid until CRT goes to ignite. A click is heard then the green power LED blinks.
I found service manual diagram of repair part or parts and install instructions
HTTP://WWW.servicemanuals.net/results.aspx?type=SM&brand=100&model=27ts54
I request any info or tips you might have pertaining to this problem
Thank-you
Sincerely
Gmyers@sbcglobal.net
2/20/2008
P.S. 25”-27” CRT board APT187
Possible Answer Posted by PEE_WEE 4/28/2005
On the CRT circuit board(picture tube), you will find R3340, which is a 10 ohm 1/3w resistor. The location of the resistor is printed on the bottom of the ckt board. It is burned open, replace with a 10 ohm 1/2w resistor. This will solve your problem. The original resistor was sized too small, should have been a 1/2 watt. This resistor is mounted standing up on ends. Mount the replacement resistor the same way. Be careful and don't get the circuit trace too hot and damage the circuit trace. (it's very small) The resistor is located on the crt(cathode ray tube), pcb(printed circuit board) socket. The resistor supplies apx +200v to the collectors of the r, g, b, video driver transistors. If this voltage is low, it causes excess brightness(excess beam current), causing the set to "shut-down". If the shut-down is too quick, you will NOT see the excess brightness, because the picture tube has not warmed-up enough to display anything on the picture tube. To see if the set displays "excess brightness", you will need to turn the set "on" about 5 to 10 times. This will heat the picture tube enough to display "excess brightness", IF that is the PROBLEM. Of course, there are OTHER defects that will cause a tv to shut down. There are built in safety circuits, that will "activate" if excess voltage/current or heat is detected anywhere in the set.
NOTE
My resistors are not numbered the same on my crt board APT187. GSM 02/20/2008
Was this helpful?
Yes
No
Popular Solutions for Samsung TXK2754 27" TV
Questions and Unsolved Problems for Samsung TXK2754 27" TV
Do you recommend Samsung TXK2754 27" TV?
Answer
Answer
My Samsung txk2754 has alot of horizontal lines (white lines) what could be the problem
Answer
On one of the channels it blacks out and say's "Current Rating/Received RatingTV14/Excessive... (More)
Answer
I tried 0711 and that didn't work......does anyone else know how to do this?
Answer
Someone gave me the TV since my old one died.  Can't hook it up, just has "AV1"... (More)
Answer
hlo tv lcd acer basic schematic acer 3201
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung TXK2754 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
