When you clean the Ac unit, Make sure to take the Unit completly out and clean both the condensor coil as well as the Evaporator coil.
If you are able to run the unit with it out of the window. See if there are any service ports connected to the unit (Guage hook ups), or any OIL spots where is looks dark, (Checking to see) if its leaking.
Wasnt sure how you cleaned the unit, So just make sure both coils are cleaned well with water, and make sure to avoid getting to much water into the Electronics.
Good Luck!
my whirlpool window a/c unit runs part of the time. Problem seems to be in the ground fault plug...
(More)
my whirlpool window a/c unit runs part of the time. Problem seems to be in the ground fault plug which has test/reset button. This is 220v, 25000 BTU sytem. Would it hurt to take off the ground fault plug and connect regular 220 plug
My LG window A/C quit working yesterday. The re-set button will not stay triggered. Unit lights up...
(More)
My LG window A/C quit working yesterday. The re-set button will not stay triggered. Unit lights up when pressed but only for a split second. Unit is less than 1 yr old.
My unit is definitely in Cool Mode, but acts like it is in Dry Mode. Dry Mode is meant for keeping...
(More)
My unit is definitely in Cool Mode, but acts like it is in Dry Mode. Dry Mode is meant for keeping humidity down with minimal cooling. However, my unit seems to think it is always in Dry Mode. I have unplugged it, cycled through the modes, and screamed at it. No matter what I try, all night the cycle repeats - compressor on one minute, fan blows for a few minutes and the cycle repeats. This unit is 2 months old and worked great until a few days ago. My bedroom was ice cold before and the unit had no problem at all.
A code comes up CH????& the air conditioner won't turn on whats the problem???? I cannot...
(More)
A code comes up CH????& the air conditioner won't turn on whats the problem???? I cannot find my manual.
