Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Brother 4750e The fax machine is printing a full sheet of black ink everytime. It doesn't print any letters at all just black on the whole sheet. Do you think the fax still works or is it broke.
    Scholar:
  • 159 Answers
No you're ok. This machine uses the DR 400 drum. What has probably happened is 1 of 2 things. Either the charge corona wire is dirty or at worst is broken and missing. You can't see the wire itself as it's too fine. What you can see is the cleaning felt which is attached to a blue plastic slider located on the underside of the drum unit. Remove the drum and toner from the machine, locate the corona wire cleaner and slide it across the machine 2 or 3 times, remembering to re-locate in it's starting position afterward. Now if this doesn't work. Then I'm afraid you will have to replace the drum.
Posted on Jan 01, 2008
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
The yellow ink will not print. There is definitely ink in the cartridge. I have tried the cleaning process 4 times.
  1. Print a Print Quality Check Sheet.
    1. Press the Ink or Ink Management button.
    2. Press the up or down arrow key to choose Test Print. Press OK.
    3. Press the up or down arrow key to choose Print Quality. Press OK.
    4. Press Color(Colour) Start.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  1. The LCD asks you if the print quality is OK for black and the three colors. Choose No.
  2. The LCD asks you if you want to start cleaning. Choose Yes. The machine starts cleaning the print head.
  3. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
  4. Repeat the cleaning and the quality check process following the Step 7-9.
  5. Compare the second or third Print Quality Check Sheet with the first one you printed in Step 1:
    1. Press Stop/Exit.
Note We do not recommend frequent unplugging and re-plugging of the machine and/or leaving the machine unplugged for extended periods of time.
  • To maintain premium print quality, our product is designed to automatically clean the print head periodically. When the machine is unplugged, it will not complete the periodic cleanings needed to ensure ink does not dry in the print head and may cause poor print quality.
  • Machines with a Message Center or Fax Preview have a 24 hour memory backup. All other machines have a 1 hour memory backup. If a machine is unplugged beyond the memory capability, the clock data is lost and causes the machine to reset. When the machine is plugged back into the outlet, the internal clock resets and the machine will automatically start a cleaning process causing the consumption of ink.
We recommend using the On/Off or Power Save button to power down the machine. Using the On/Off or Power Save button allows minimal power to the machine ensuring periodic cleanings of the print head occur only when necessary and needed information remains in memory.
Caution
  • Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
  • DO NOT touch the print head. Touching the print head may cause permanent damage and may void the print head's warranty.
  • Brother strongly recommends that you do not refill the ink cartridges provided with your machine. We also strongly recommend that you continue to use only Genuine Brother Brand replacement ink cartridges. Use or attempted use of potentially incompatible ink and/or cartridges in the Brother machine may cause damage to the machine and/or may result in unsatisfactory print quality. Our warranty coverage does not apply to any problem that is caused by the use of unauthorized third party ink and/or cartridges. To protect your investment and obtain premium performance from the Brother machine, we strongly recommend the use of Genuine Brother Supplies.
    > Brother Genuine Supplies information
Oct 28, 2010 | Brother MFC-5890CN All-In-One InkJet...
Can receive a fax but when sending a fax it sends a black sheet
YOUR SCANNER LED LAMP IS DEFECTIVE. IF ITS NOT UNDER WARRANTY YOU SHOULD JUST PURCHASE ANOTHER FAX
Aug 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Printing on line
try unplugging the machine then replug good luck
Jan 28, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
INK
Brother multifunction printers require that all ink be filled before you can print to it. If any ink is empty, you cannot print, even if you are printing only black.
Jun 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
My brother fax machine is indicating that two color cartridges are almost empty, however i never print anything and color, and basically everything is black. so how can they be almost empty?
Three reasons -
If your print driver is set to color. It will use all the colors to make black.
Because the machine is ink jet it needs to clean the print head to stop it from drying out. It will use color ink to flush the print head every two days.
When ever in receives a fax it will use some color when printing a fax, particularly Cyan.
If you only wish to print or receive faxes in black there is now a version of Brother fax that only uses black ink and has no color inks. However it may not be available in your region. If you try and cheat the system you will only kill your print head.
May 02, 2008 | Office Equipment & Supplies
Brother intellifax 4750e
You need to open the front cover, then press the "Clear" button, and then press "1". This will reset the drum counter.
Mar 27, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
118 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
