Question about NetGear DG834G Router
Wired works fine wireless does not
A wired connection from cablemodem to laptop works fine, however, when connection wireless i get no response and no ip address, even though the netgear has been working fine for years and signal strenght is "excellent" i have tryed rebooting everything several times and doing an ipconfig /release and renew and still no connection via wireless.
    Sergeant:
    Champion:
  • 310 Answers
What is your ip and subnet addresses? are they complete? sometimes I enter my own in the alternate tab. eg.
ip; 192.168.1.105
sub; 255.255.255.0
gate; 192.168.1.1
dns; 192.168.1.1
alt dns; 192.168.0.1
Posted on Dec 31, 2007
My wireless connection to my Sharp smart tv works - but the wired connection does not. Should the two IP addresses be the same or different for wired and wireless?
For the same hardware on your system the IP address needs to be the same, no matter how its connecting to the router. Also check your available IP addres range on the router. The IP address must be within the routers IP address range or it will not see it.
Aug 10, 2014 | Sharp Aquos Televison & Video
My playstation won't connect to the wireless connection even though the internet is fine as both laptops in the house work fine. I have tried testing it and the test fails at obtaining the IP address, I've...
sometimes the router can be set to high on the wireless security side of things for example WPASK wich is 256mb encription wireless aand some adapters do though you out!
Nov 27, 2010 | Sony Playstation 3 (PS3) Console
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
My dell inspiron 1545 wont connect to linsys-g
Your laptop may have a pre-defined Ip address locked in for your work connection. Did your buddy use the laptop at your place of employment, or was it used at his home? Sometimes an ip is entered manually in the tcp/ip menu locking it to a certain address. To check this opem metwork connections in control panel and right click your wireless device then choose properties and left click. Scroll to the TCP/IP line and go to properties. Make sure everything thereis set to automatic.
Mar 13, 2010 | Dell Inspiron 1545 Notebook
I set up the Engenius EAP as a repeater and can connect to it with my lpatop and Iphone. When I try to connect another laptop I have excelletnt connectivity reception, but Internet Explorer cannot display...
Signal is only one part of the complete connectivity problem. Your lack of connectivity is almost certainly due to some other component, such as your second laptop having an incompatible static IP address specified, or no DNS servers specified.
First, ensure your PC is configured for a dynamic IP address. Once you have acquired good signal and connected, check to see that you have received a dynamic IP address. If that works, open IE and type in the numeric IP address if your EPA repeater. If you get a response, the problem is not your wireless connection or local IP address. Now type in the IP address 74.125.19.103 . If you get a response, your problem is that you have no DNS servers specified.
Feb 28, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
Have D-link DIR-615 router and Comcast for internet - just recently got a Macbook Pro laptop but cannot get it to connect to internet. Keep getting message that it cannot find IP address even though I've...
Did you set the IP address manually on the other computer? Is your router set to act as DHCP server and assign IP addresses automatically? If everything is set to DHCP then check the router and make sure it is transmitting on channle 10. Most providers set the cahnnel to 6 which has issues with HP laptops on occassion and maybe effecting you as well.
Aug 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
New wireless adapter will not get IP address
plz i want to dsl wireless connection plz call then now +92332330458
May 03, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
I have a sony vaio laptop running xp sp2 connected wirelessly to an HP C4385 printer. I can't get it to print in this wireless mode and I can't get a response from the printer when I put the printers IP...
I suggest you network the printer and access it through the wireless access point.
Also, I do not mean to insult your computer smarts, but if you do not have a driver installed, you will not be able to talk to the printer at all.
Aug 14, 2008 | Computers & Internet
NetGear DG834G Router Logo
148 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
