ive got a reddy heater pro 155 when you turn it on it runs rich burns youre eyes fumes i took it to a man that works on them here local and he said the board that controls fuel mixture was bad what do you think
Are you sure it is running too rich? Your eyes will also burn if it runs too lean because the hyrocarbon and nitrous oxide balance is off. If too rich, there usually is a smokey vapor that is emited, whereas too lean does not create any seeable vapor.
If youhave a little tech to you, you can over-ride the control board and have the power go directly to the burner (as is in the older burner models). If you get the same results, then you'll know itis not the control board. Goodluck,Macgivor
reddy heater 55, was stored for three years, now begins the start sequence, plenty of glow on the...
(More)
reddy heater 55, was stored for three years, now begins the start sequence, plenty of glow on the glow plug, can see fuel spray but does not light off, new fuel, lines clear, blew them out, seems not enough air.
I have a Reddy heater model RH 10 PT. I can light the pilot light but when I turn up the dial the...
(More)
I have a Reddy heater model RH 10 PT. I can light the pilot light but when I turn up the dial the pilot goes down and the heater goes out, any suggestions?
