e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Bewarned that opening your console voids any warranty on it, i would recommend contacting microsoft to see if it is still under warrenty as this could be a free fix by them
my xbox is having the invalid format problem...happened while playing, the colors went weird so i...
(More)
my xbox is having the invalid format problem...happened while playing, the colors went weird so i turned it off. when i turned it back on it says invalid format but there is still audio, it sets up normally to the dashboard (i know this by the audio) and the power light is green as normal. after playing around with it a bit it no longer says invalid format but instead now says no signal at all. the rest still working normally. any ideas for advice or solutions?
the tray don't open or close you push the button and nothing happens and on the screen it will say...
(More)
the tray don't open or close you push the button and nothing happens and on the screen it will say opening or closing but its not doing anything so what can it be is it considered a tray or dvd drive is there something i can do. I want to get this fixed my son has never been able to play it. What a birthday present huh idon't know much about these i do know that when you push the button the tray should come out so you can put a game in it. Can someone help me
