I have same problem and it happened from day ONE. Have shipped it to repair numerous times. They have replaced everything they could think of and it STILL does it. You can try all those things, none will work. I eventually just had to buy a new laptop because after over a year of reapirs, they said out of warranty. They wouldn't even give me a small credit towards a new one. I was NOT amused.
check if the fan is working properly, the place you use your laptop, must have breathing space, for ventilation, e.g, if you are using it on bed, then place somthing underneth, if all these are fine, then check out your battery, or cmos battery, could had gone bad in times of using..last options are RAM, PROCESSOR..
I have to push really hard to get juice from the power supply to the laptop. Battery seems to be...
(More)
I have to push really hard to get juice from the power supply to the laptop. Battery seems to be holding charge. It occasionally doesn't want to boot, the power lights will come on and the fan will run but the screen is black. I turn it off and turn it back on again and it is fine.
2 months ago, expereinced sudden power lose, system shut down immediately due to that. solution back...
(More)
2 months ago, expereinced sudden power lose, system shut down immediately due to that. solution back then, disconnect battery, shook for a while, replace battery and hook up a/c. it worked. Now, for no apparent reason, not able to turn on pc at all. suspect motherboard problem and wanting to replace the intel centrino mobile motherboard. Presario v2000 s/n:CNF50806PQ p/nPV255PA. purchased from hong kong, now hard to find intel centrino mobile motherboard for it. any recommendatons
