Home | Toshiba | 43H71 43 in. Rear Projection Television | Toshiba 43
Toshiba 43H71 43 in. Rear Projection Television
Problem for Toshiba 43H71 43 in. Rear Projection Television
Toshiba 43
By tshaw236 on Oct 25, 2009
toshiba 43'' projector tv seems to not have any green in the picture.
have tried new scart lead & adjusting the picture colour.
Solution #1
posted on Oct 25, 2009
Not Rated)
stergiou88
Rank: Wiz
Rating: 83%, 22 votes
unfortunately the green color bulb must have burned. you should go to a repair shop.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 43H71 43 in. Rear
Questions and Unsolved Problems for Toshiba 43H71 43 in. Rear
Do you recommend Toshiba 43H71 43 in. Rear Projection Television?
Answer
Answer
the picture is messed up- the colors are separate and shadow-like.
Answer
tv will turn on but have no picture. the power light does not flash just stays constant
Answer
Toshiba flat panel model #PDP42X3 shows no picture but has static sound is it fuses? How do I know... (More)
Answer
toshiba tp61f90 no picture when i hook up cable to either tv video 1 or 2 standard cable jack. if i... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 43H71 43 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
