Question about Xerox Phaser 8500/DN Printer
Internal diagnostic mode
How do you bring that up on the printer? Which buttons do you press
  • poopie187 Dec 31, 2007
    Tryit
    when I turn on the computer and try the red button (c) and the OK button it loads up and then the printer error shows, none of the other info you wrote comes up.
    President:
  • 2,072 Answers
To enter Test Selection mode from Customer mode and display the Test Selection screen:
  1. Select Information -> Troubleshooting -> Service Tools from the Control Panel.
  2. Scroll down to Enter Diagnostics and press the OK button.
When the system transitions from Customer mode into Test Selection mode, the initial Control Panel display is the Test Selection screen as follows
Posted on Dec 31, 2007
  • Rick Kasper Dec 31, 2007
    Oh. ok.
    Are you getting an error code?
    some number like 00,000,00 ??
    Is the red light just flashing? indicationg possible a sliver of paper stuck somewhere?
    Ok if there is an error number please provide me those and I will look it up and provide you the best answe I can.
    Thanks
    The number will be a 2 digit code with a comma, 3 more digits a period and 3 more. Those are the numbers I need. Anything after those first 8 numbers don't mean much.
How do I get into the diagnostic mode for the kodak 6850?
With printer off, press and hold "+" "-" and "menu" button at front panel. Then turn on your printer. keep holding the 3 buttons until you see "diagnostics" appearing on the lcd screen then let go of the buttons. you will be in diagnostic mode.
press the "menu" button once and you will see diagnostics. press "enter" button then "menu" button again until you see "check cutter"
Feb 19, 2015 | Kodak Photo Printer 6850 Thermal
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Error on wc 7120 xerox 124-315
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
hen look at these 3 locations and see if they match, If they do not set them to match the machine speed.
Mar 12, 2013 | Office Equipment & Supplies
Can I check how many copies I have made on my printer
Please access the Diagnostics Menu.
To enter the Diagnostic Mode:1. Turn the printer off.2. Press and hold the Go and Return buttons.3. Turn the printer on.4. Release the buttons when "Performing Self Test" displays onthe operator panel.
Once you are in the Diagnostics Mode, choose Printer Setup and then select Permanent Page Count.
Aug 01, 2012 | Lexmark Optra S 1855 Laser Printer
Reset printer lexmark
2. Enter the Diagnostics Mode by holding down the GO and RETURN buttons while powering on the printer until the display reads PERFORMING SELF TEST. When ready, the display will read PRINT REGISTRATION
3. Scroll to PRINTER SETUP and press the SELECT button
4. Scroll to MAINTENANCE PAGE COUNT and press the SELECT button
5. Scroll to RESET MAINTENANCE COUNT and press the SELECT button to reset the count to zero
6. Press the RETURN button to return to the Diagnostics Mode main menu, then exit Diagnostics Mode to return to normal mode
Feb 15, 2012 | Lexmark Pro205 AllInOne InkJet Printer
Error3-315 when machine on error come in most times
3-315 Fault Code indicates that a communication failure
between the IOT PWB and the Post IPS PWB was
detected.
You may be able to enter diagnostic mode and reset:
Entering Diagnostic Mode: First of all... to enter the User Interface (UI) Diagnostic Mode: Turn on the power... then while holding down the '0' button, press 'Start'. The screen will prompt you for an "Access Number"... use the keypad to enter '6789' which is the Default Access Number. This should bring you to a menu of options to choose from:
NVM Reset (Non Volatile Memory) / NVM Initialization
NVM Read / Write (memory adjustments)
Component Control (for testing sensors, motors, etc.)
Print (for running Test Patterns from Diagnostics)
Subsystem Check (for fuser nip measurement check out, and developer unit check out)
Max Setup (for setting up copy quality)
If reset does not work, you need service on the unit.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 11, 2011 | Xerox DocuColor 12 Printer
Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2009 | Dryers
My Fisher paykel dryer does not heat
Thermostat Cutout – Manual Reset (Electrical)
Type SPST 30 Amps/240 Volts AC
Trip Temperature 212°F (100°C)
Diagnostic Mode
button.
Last Fault
Conductivity Contact Impedance Check
To enter the conductivity contact impedance check, enter the diagnostic mode
as described above, then press the Auto Dry up button five times. In this
mode, touching damp clothes or fingers across the conductivity contacts will
cause the LED display to change. If the contacts, or the harness to them,
have gone open circuit, no change will occur in the LED display. This is a
useful method of checking the integrity of the sensor circuits.
To exit the diagnostic mode, press any cycle button.
Entering the Data Download Mode
button. This enters the diagnostic mode.
(c) Press the Regular button.
Encoded data is transmitted serially out the red Auto LED, and is be captured
by an optical download pen attached to a PC where “Smart Tool” software
interprets the data to aid servicing.
To exit, press the Regular button.
Entering the Showroom Mode
(b) Press and hold the Air Dry button, then press the Power button.
The LEDs will flash in a random sequence.
To exit, turn off the power supply to the dryer at the wall.
Tell me what sort of faults codes you can come up with and I will tell you what it means but in the meantime reset the limit and clean out the lint problem, open the stopped up vent. That dryer has to breath or that safety will kick out again. I have the manual
Sep 05, 2009 | Fisher and Paykel DEGX1 Electric Dryer
B8300 toner error
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Jun 12, 2007 | OKI B8300 Laser Printer
Aligning Print Head Alignment
Try printing a diagnostic page without the PC, if it prints normal then the problem is on the PC, probably drivers or possibly the printer queue configuration. If it prints the same faded fashion then I would suspect defective or clogged inkjet nozzles. Warning, be very precise with the buttons you push, you are entering the printers diagnostic mode and you can cause problems if you push buttons out of sequence or if you push them too many times. - Start with the printer off. - Hold down the resume button and then hold down the power button - Release the resume button - Press the resume button twice, then release the power button. - Let green light blink while the printer enters the diagnostic mode. - When the printer is done press the function button once to enter the print diagnostic page mode, then the power button once to start the job. - When the page finishes press the power button once to exit the diagnostic mode. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 14, 2007 | Canon i850 InkJet Photo Printer
Xerox Phaser  8500/DN Printer Logo
770 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
