Question about Radio Shack Pro-84 Handheld Scanner
LCD backlight interfearing with scanning
When I turn on the backlight on my Pro-84 scanner it tends to lock up on some of the CB channels. This tends to happen more when I hold it vs. putting it on a table. I've turned up the squelch which as helped somewhat but still has not completly eliminated the problem. Any solutions?
    Problem Solver:
  • 8 Answers
I turn on my pro -97 Handheld Scanner and it displays all channels are locked
Turn the scanner on and make sure that you don't see a "key" in the display- if you do, you first have to press and hold the key LOCK button until it beeps and allows you to use the keys. press 'manual'. press and hold 'L/O' 'lockout' for 3 seconds and it will unlock all locked out channels. now press 'scan'. if you have nothing, then press 'scan' again and press each one of the number keys to turn off and to switch on the scanning banks. Okay? Let me know if you need more help.
Apr 04, 2014 | Radio Shack Pro-97 Handheld Scanner
How do i start scanning for channels on my bc 855 xlt scanner
Firstly, you need to program your favourite frequencies into it, before you can receive anything, all the info on setting up your scanner is in the user manual that came with your scanner, if you bought it new, that is.
Cheers,
Peter
Jul 26, 2011 | Uniden Bearcat Pro PC78LTW 40-Channels...
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
I'm using the pre set cb radio band to scan cb, howevre I locked out a few channels that I would like to unlock. how can I do this?
press the manual button until you get to channels you locked out, then press Lockout and they will unlock.
Thanks,
Dodgem250.com
Apr 15, 2010 | Radio Shack Pro-97 Handheld Scanner
How to program my uniden bearcat scanner bc350c
to listen to the programed channels you need to turn the squelch up to to the right and press scan it will scan all the channels and stop on the ones that people are talking on. you can down load the user manual at the bearcat scanner website.
Jan 19, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Program prblems
your scanner has an attenuater.it lets you program your scanner to reduce scanners sensitivity .check to see if its on or off.
Jan 06, 2009 | Radio Shack Pro-95 Handheld Scanner
Stuck on scan mode
Hi, It sounds to me like your keypad is locked. Pg 63 of your manual.
***using the keylock ***
Once you program your scanner, you can protect it from accidental program changes by turning on the key lock feature. When the keypad is locked, the only controls that operate are FUNC, key , SQ, and VOL. You cannot activate the keylock while you are entering a frequency into a channel. To turn on the keylock, press FUNC then key . Key locked appears for about 1 second. Key locked appears when you press any key after locking the keypad.
To turn off the keylock, press FUNC then key . The scanner beeps three times and Key unlocked appears.
The only other choice I see if that does not work would be to initialize it. Pg 84 of your manual. Hope this helps you,, Mechanic
Jan 04, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-84 Handheld Scanner Logo
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
