Question about Onkyo TX-SR803 Receiver
How to play XM Radio on zone 1 and zone 2 in sync
When I play my XM Radio, sometimes I like to play zones 1 and 2 at the same time (indoors/outdoors). The problem is there is a delay of 1/2 second or so between the two. How do I get then to play in sync?
Examine the operator's manual for the page explaining the video delay adjustment. Also examine the speaker wire line ends for proper shielding, continunity and polarity placement.
Posted on Feb 05, 2008
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
How do i set the system to run 2 times per day
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
Jan 03, 2014 | Weathermatic ProLine PL1600 Outdoor/Indoor...
Cant fix the time zone
Successful reception of the time-synchronization radio signal is indicated by a radio waves icon to the right of seconds in the upper section of the display. After synchronization occurs, you can select your continental U.S. time zone (EST, CST, MST, or PST) by means of a switch on the back of the clock.
Feb 15, 2010 | SkyScan 86742 Digital Atomic Wall Clock
No sound from zone 2 speakers
yes,usually thugh the reciecer borrows power from your rear speakers so you(center channel) so you wont get that
May 11, 2009 | Audio Players & Recorders
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 | Watches
Zone 2 Can't Handle a Digital Input ? ! ? ! ?
it is very frustrating... I just have discovered today. I can't solve this because my Itunes mac is only digital audio output, I can share its sound to Zone 2..
Apr 16, 2008 | Audio Players & Recorders
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
Dec 12, 2007 | Apple iPhone Smartphone
2 zone setup
Consult the user manual. If you don't have one, it can be downloaded free at Denon's website. Two of the speaker oututs serve multiple functions. Hookup and setup need to be checked. What you want to do is possible as long as you're only using a 5.1 setup indoors.
Sep 02, 2007 | Denon AVR-1507 Receiver
Onkyo TX-SR803 Receiver Logo
181 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
