  • 579 Answers
Make sure it has a signal going into it and that you can see it on your TV (put the VCR in vcr mode by pushing the vcr/tv button) , put in a tape and hit the record button. (some vcrs you push the record and play buttons at the same time)
Posted on Dec 31, 2007
VCR stops recording by itself after a couple seconds.
Some VCR's will stop if the signal is not there. Retune the set if it uses Freeview. The broadcasters and those who are in charge of Transmitters like to mess around with the stations from time to time. This will effect the recording if you are using a model with the Guide Plus system. If you are timer recording it make certain that the settings are good. If it is an older model, make certain a thing called PDC is not on.
Dec 16, 2015 | Panasonic PV-7450 VCR
Panosonic vcr and dvd when turned on says error
Clean the optical pickup lens, by inserting an lens cleaning disc in to the device, and play it. If this do not help you, replace the optical pickup unit.
Jun 06, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
Unfortunately, no. The VCR only has the older analog tuner and can't get digital channels. You'd need a converter box connected to the VCR for those.
Apr 12, 2009 | Televison & Video
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Panosonic dvd recorder
Make sure your aerial's RF lead goes to the DVD first then out of that into the TV.
Apr 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Vcr timed recordings
I'd be pretty certain that every VCR made these days (and of the last 10-15+ years) can be set to do a timed recording. They can be set for a one time recording, weekly or daily record. Whether used with a cable/satellite box, or outside antenna, you must ensure proper hookup. I'm not real familiar with recent cable/sat receiver boxes, but older ones had to be set to the channel you wanted to record, as the VCR will only see that channel. On older cable (no cable box) & outdoor antenna systems, a VCR could tune in and record any channel, while you watched another one. Anyway, check the capability of the cable/sat box, and follow suggested hookup. You will likely need to set the box to the channel you want to record before you retire for the night.
Sep 26, 2007 | Televison & Video
How Do I use timed recording?
Is this a problem of the VCR not doing a timed record at all, or of it recording only snow (no signal) or perhaps the wrong channel? If the first, then it would point to incorrect setup of the timed record session or that the clock time & date settings are incorrect... the VCR setup stuff. Also, once the timed recording is setup, there is often one additional button to push to actually ready the VCR. Older VCRs, were put into the timed mode by power off. If VCR isn't recording anything (it is coming on to record, but no signal), then it has to do with hookup of the VCR. Depending on your cable system, the VCR can only record the channel the cable box is tuned to. Again, depending on the system, the VCR needs to be cabled in between the cable box and your TV (cable box RF out to VCR RF in, VCR RF out to TV RF in) RF=ant. Exact cabling will vary.
Apr 26, 2007 | Memorex MVR4052 VHS VCR
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
