Question about Kenmore 94802 Front Load Stacked Washer / Dryer
Kenmore stackable Clanging on one side when the washer spins. load is balanced. Can this be fixed? How?
    Scholar:
  • 61 Answers
I just fixed this same problem last weekend. First, you want to look under the machine. Get someone to help you tilt the machine until you can see the three big springs underneath the washer.
On my machine, it turned out that one or two of the the big springs that hold up the tub were either broken, or had jumped out of their sockets. Go to the parts depart of the Sears website, and give them a call. Don't bother with searching for your model number, because it doesn't usually work in the search.
You may need to also replace the bottom tray if the threads holding the springs down are stripped. Either that, or you can get some 1/2" nuts to hold them in place after you get the new ones. The set of three springs costs about $80-$90 dollars (not including shipping). The set also has excellent instructions on how to replace the springs. Took me about 2 hours to do by myself. If you're handy around basic mechanics, then I would highly suggest doing this yourself. But check the springs first before you go ordering them.
Posted on Mar 16, 2009
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Have a stackable Kenmore 24 goes out of balance
this is the whirlpool thin twin design.you'll need to replace 3 shocks and suspension plate.big job ,costly $400 +.Hope this helps,please rate my response :)
Dec 09, 2009 | Kenmore Washing Machines
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer noisy while spinning
You probably have a balance problem. You will have to get a service tech to replace the shock absorber/stabilizers (there are 3) in the unit.
Jan 31, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Oasis top load always out of balance and bangs
First just to let you know, the oasis is very sensitive to the load level and water ratio if its too heavy the load has to be perfectly balanced inside the tub. Next check to see if any of the straps are broke. The next thing is that the newtator has tighted up all on its own so when it spins the newtator grabs the tub while it spins at high speed. I have never had to fix this but i know it is a common problem. I hope i helped a little. Good luck!
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 94802 Front Load Stacked Washer / Dryer Logo
56 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
