Fisher and Paykel GWL11 Top Load Washer
Problem for Fisher and Paykel GWL11 Top Load Washer
We have a Fisher & Paykel GWL10, the problem
By rkleefam on Oct 25, 2009
We have a Fisher & Paykel GWL10, the problem we have with it is that when we start the machine in the normal cycle it will start to fill then will stop filling and after about 30 seconds will start to fill again and at the same time pump water out. If we start the machine in any other cycle and wait for it to fill and start agitating and then change the cycle to normal it will finish the load. It also works ok in the complete cycle on any other setting. I bought a service manual and checked for any fault codes and it shows none, unless I am not doing it right.
Comments:
Oct 25, 2009
- I didn’t think this was the problem but I checked it all, both plastic filters (1 blue 1 yellow) clean no rust, I cleaned them anyway with limeaway. Both valves tested ok. My wife said I didn’t explain this quite right. Both; Regular and Heavy Duty cycles do the same thing. They will fill for about 1 minute stop for about 30 seconds and start to fill again but, at the same time it starts pumping the water out. If we start the machine up in the Permanent Press cycle, it will work correctly or after it starts to agitate, we can switch it to Regular cycle and it will complete the wash cycle.
Oct 28, 2009
- What timer, we are looking at a GWL 10 ECOSmart Washing machine. Also why would it work in one type of wash cycle and not another ; sounds like nothing to do with a timer to me to start with even if there was such a thing in it.. Also there is no manual setting, all electronic. I think you better have someone else look at my first two messages.
Oct 29, 2009
- Since this was my first step (checking the valves) I will have to agree with you. I was just baffled as to why there was no fault codes showing. Will look for a new board on Ebay, and a few other places.
Solution #1
posted on Oct 25, 2009
Not Rated)
GodBlessU
Rank: Wiz  Washers & Dryers  Expert
Rating: 85%, 146 votes
Check the water inlet valve. Unplug the machine and turn off the water. Remove the water supply hoses and check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid.
Thanks
Solution #2
posted on Oct 29, 2009
Not Rated)
milten1
Rank: Guru  Washers & Dryers  Expert
Rating: 90%, 483 votes
ok
I will admit, one of the most dertailed explanations here, I have been reapiring these units and I have never come across this, particular problem.
Although I will tell you this, the problem is in your programming,
or your cold water valve is clogged,, the fill and drain thing is temp control issue,,, it is actualy calibrating the tank water temp, for the required normal wash temp.
Unplug the machine,
Turn off your water, and disconnect, your hoses, hang a towel over the control panal, any water here is dangerous...
inspect your water valve screens, cold inparticular..
then open the control panel..... from the top and remove your control cover,,,,,,its important to unplug this first for feedback issues
on the left you will see your water valve, unplug the solonoids,, ohm these out, you should have continuity through the coils on both valves, they must be unpluged to isolte the coil.
if both of these are good. ITs your control board, or programming issue.
More often then not its a burn resistor on the board some where in the water circuit..... I wont pretend to be an engineer, I never understood why you need such a circuit to open a valve, but hey..... im just a blue collar guy.
Parts are not hard to find, and the reapair can easily be done by you
they are available at www.searspartsdirect.com
the part number is 426930P......
please be advised this part is $200.00,,,,, and without actually taking the voltages myself, i could no way guarentee this is correct.
these machines have a way of making anyone look foolish.
but if you can understand my driblle here, it should get you on the right traqck
Solution #3
posted on Oct 30, 2009
Not Rated)
venexcsd
Rating: 88%, 411 votes
It is possible that the water flow to the unit is low and the timer is advancing before the drum is full
Check the inlet valve for blockages, to do so you have to start the machine as if you are doing a wash but turn the water supply off.
This will release the pressure in the supply lines
Undo the connector on the back and look inside the valve entrance for dirt or grit in the filter , if it is dirty you can pull it out using a paipr of fine nosed pliers.
Re-assemble and test
After that you are looking at obstructions in the pressure switch line or the pressure switch itself
Comments:
Oct 30, 2009
- You could try pre-filling the machine via the with water with the load in then close the door and see if it washes ok
Other whacky test is if the machine is filling to a lower level on the other two settings than the one you are having problems with and the outlet pipe is not providing a good air break you could be activatng a syphon action on the outlet hose which would give the effect of a drain out
Solution #4
posted on Oct 26, 2009
Somewhat Helpful)
johnrray7526
Rating: 90%, 363 votes
I have reviewed your problem and have the fallowing items for you to access.
First, this sound like your timer has taken a turn for the worst.
If the unit will complete a cycle, once started manually, the timer is the part you will need to look at.
Below I am leaving you a parts look up website for your unit but can only go so fare with present information.
Hope this works for you, a timer is allot cheaper than a motor or transmission part.
Good luck, hope this works for you.
Please rate....
http://www.repairclinic.com/Washing-Machine-Parts?s=t-Paykel+GWL10-%3d%3da11&n=3
Comments:
Oct 29, 2009
Popular Solutions for Fisher and Paykel GWL11 Top
Questions and Unsolved Problems for Fisher and Paykel GWL11 Top
Do you recommend Fisher and Paykel GWL11 Top Load Washer?
Answer
Answer
My Fisher& Paykel washer has a constant drip coming from the fill tube inside. Is there a... (More)
Answer
F & P Model GHL 11, water drips in the washer when it is not on.
Answer
The following problem has started taking place every few washes but not every time. My Fisher Paykel... (More)
Answer
Our GWL11 has been squeekinng and now it will not spin dry and it smells hot
Answer
Washer starts filling with water nicely and then the water goes down to a trickle. It is taking at... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fisher and Paykel GWL11 Top...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
