Question about Siemens SX66
Re: Siemens SX66 , Broken Screen!!!
I accidentally drop the the phone on a hard surface and the glass part of the screen cracked. I can still see about 90% of some of the content, but wanted to know if the glass can be replaced , by me or a sercive station? Also in the long run will it get worse seeing the content???
  • 3 Answers
Same thing happened to me. mailed it in for lcd replacement by good work, easy process. they also sell accessories.
Posted on Jan 30, 2008
  • 3 Answers
Sounds like the LCD screen is cracked, and needs to be replaced. You can e-mail me at for more info or you want it repaired. DAVE.
Posted on Jan 24, 2008
How did my display get broken?
Typically this happens because the phone is dropped onto a hard surface on the edge or it falls display down not a surface that has a pebble or some other small surface that is sharp.
Other people place in a pocket causing stress to the screen. While damage may not be visible small invisible cracks can become big ones under repeated torsion.
Motorola Support
May 07, 2014 | Motorola Cell Phones
I have screen protector on my HTC hd7 and I have small crack on the corner (vertical) right lower. Can be repair?
The screen of the hd7's is made using corning's gorilla glass. Technically but also simply put, it's made of a single sheet of glass, spreading along all the front side of the phone. Glass is being used since it's more resistant to scratches and is a good electrical insulator, a needed property in the making of capacitive type touchscreens.
If you have a crack, most probably the surface area was broken due to some mechanical shock. Like any piece of glass, once broken it can't be fixed, it doesn't work like fixing a scratch on a plastic cover by polishing it. In fact i recommend you to leave it like this and try to cover it with the screen protector. The surface on the glass layer contains a special compound of transparent conductive polymers used to register screen taps. Actually this is what you touch when using the screen. It's not recommended that you try to polish the screen because you can accidentally remove this layer.
So, again simply put and sorry to make it this way, the wisest thing would be to either try to live with it or change the digitizer layer (glass front cover) but the last option can prove to be a bit expensive. Again, sorry for not being able to provide a more nicer solution.
Jul 20, 2011 | HTC HD7 Cell Phone
Siemens SX66 align screen does not get aligned.
Go to system/screen/align. Realign
Oct 27, 2009 | Siemens SX66
Freezed SX66 at the initiation Windows page
This could be an internal problem on the device, cause of instant shock cause of dropping it. You better try to remove the battery for a while to reset and restore the system.
If the above recommendation did not solve the issue, try to remove the memory card, if still not working try to update the firmware of your unit.
Let me know here again for the update.
Jul 19, 2009 | Siemens SX66
The touch screen on our Garwin Nuvi 360 do not function.
Unfortunatly there is a fine wire Grid below the surface of the glass, the grid detects where you are touching on the screen, with the glass being broken, the grid is broken, which will cause dead spots or regions on the touch screen. You will have to replace the Touch screen or the unit which ever is most cost effective.
Hope this is of some help.
Apr 18, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Phone keeps rebooting
is the button near the reset hole? possibly the button is somehow pressing the reset switch, possibly stuck somehow. Other than that try a hard reset, instructions below.
Soft Reset
Put your stylus in the hole in the lower left corner where it says “Reset” Soft Reset will reboot your device just like when you reboot your PC. No data will be lost, under normal circumstances that is.
Hard Reset
Hold down the Power button (Top Right corner) and at the same time put your Stylus pen in the hole where it says “Reset” (Lower Left corner).
Hard Reset will delete all data you have put on the device, Programs, Settings, Mail, SMS, MMS, etc., so be careful and make a backup before doing this.
After a hard reset, you will have a complete clean new install of Windows Mobile on your device.
Things that are not deleted
  • Data on \Storage Card
  • Data in \Storage folder
Oct 15, 2008 | Siemens SX66
Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Jun 23, 2008 | Siemens SX66
Siemens sx66 wont work
Download mitty 1.42 file from this website.
Mar 24, 2008 | Siemens SX66
Help me
Check hard reset. Turn off your pda and hold on the turn on button as same time you make you normal reset.
Nov 26, 2007 | Siemens SX66
Siemens SX66 Logo
181 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
