Samsung (SP0411N) 40 GB Hard Drive Logo
Anonymous Posted on Oct 25, 2009
Sammi James broke FIXYA - Samsung SP0411N HDD (3.5" IDE 40GB) PC board replacement
My HDD has an electrical short circuit and the board even smoked, mechanics and most probably also the motor are intact. I can get a new board of same make and model and replace it to recover the stored data. 1- Is board revision dependent, and if so which revisions are compatible between them and which are not? Mine is Rev. A of Aug 2004 2- Is board specific for each magnetic disk? 3- If so, could you guys provide me the ways (instructions, code, etc) to overcome above limitations by reprogramming firmware or wehatever other means? Thanks in advance, avg4
Chris
Level 3:
  • Master 696 Answers
  • Posted on Oct 25, 2009
Chris
Master
Level 3:
Answers
696
Questions
0
Helped
341405
Points
1874
The firmware is upgradable on these devices but only within the same Rev Series. Your best bet is to source a board with the same Rev and similar production date.
Assuming the board is all that failed this should r troubles. Try http://stores.shop.ebay.ca/Effective-Electronics__W0QQ_armrsZ1 as they carry a wide variety of boards. if they don't have it try a general search on eBay. Don't use anything more than the Samsung model # for the search though as most sellers haven't a clue about Rev#'s. Once you find a few similar ones you can ask the sellers for specifics.
If you can't find the proper board or if you do and it fails to garner results let me know and include your location(Country, State and City) and I will refer you into a clean room facility.
Chris
Testimonial: "Thanks a lot!"
Slave drive
From a manufacturers website.
Select as master
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
2helpful
3answers
I have a 80gb samsung ata hdd which is clicking is ther any way to makr it work
it's possible but i would not recommend it due to failure and losing all your data...it's simply not worth it, replace it.
Sp1203N HDD when I plug in the power cable to the HDD it shuts down the PC power supply and there is a electrical smell from the HDD unit
That's a strong sign that the electronic circuit-board under the disk-drive has short-circuited, and has melted-down.
It's time to purchase a new disk-drive.
2answers
Hard disk is not detecting samsung sp0411n internal hard disk is not detecting
Make sure the power cable and IDE cable is plugged in properly then boot your computer up again. If it does not work, test it on another computer to see if the hard drive works at all.
2answers
Samsung np-r519 turns on, but does not boot up windows. Am left with screen saying something about a boot disk!!
Hello
Ok, this code is a result of either the following 2 reasons.
It is either that your HDD is not plugged into the power cord from the mother board or the sata/ide cable is not plugged in.
or
You HDD's circuit board might have blown. I would first have a look at the cables, then test your HDD.
You will be able o read more on this error HERE.
Hope this can be of help.
Kind regards
Andrea
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
2helpful
3answers
Hdd failure
It is not smart to switch a IDE with a SATA,
it should be IDE with IDE and SATA with SATA
Each transmit diffrent levels of instructions.
The clicking is definitely not a good thing. It means you nearly shorted something out to the point where its not sending the correct impulses in power. Most likely the hard drive might be able to work. but the clicking means its blocked or somethings preventing the head from moving or doing what its supposed to do. You will need a new Hard Drive.
My recommendation is to send your old HDD to have it recovered in a clean room if you want your data from it. or replace board with like board, being exact. other wise switch the board and have a high level format for the clicking. Its the only real way to fix a HDD, but its not worth it for the cost that you will be charged. Your better off buying a new HDD
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
3answers
SAMSUNG IDE HDD SP0411N (40GB)
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
