Question about Dryers
Whirlpool Dryer tumbles, but no heat, no timer.
I cleaned the lint from the upper lint chute, and the lower vent. Now the timer does not appear to work, the dryer does not shut off. It tumbles, and blows air, but does not heat. I'm not sure where to start on this combination problem. Help?
  • grashprl Jan 04, 2008
    I did try that over the week end, but it did not help. I finally pulled the back off and checked as manyparts as I could with a meter. The heat element didn't have resistance, so I took it off and found the coils broken. I replaced it and now have heat. Thanks for your help.
  • 1,314 Answers
Try turning your breaker off then on and advise me
Posted on Jan 01, 2008
Whirlpool dryer heats and tumbles but doesn't dry
Sounds like it is still clogged up. Is the blower running?
Feb 23, 2014 | Whirlpool Dryers
I posted a reply earlier tonight and most dryers are similar in construction. You should be able to get access to the heating element but first perform the following inspection:
Many dryers don't dry if the internal exhaust chute becomes full of lint. What most people do not realize is that pulling the vent screen out and cleaning it (and possibly even using those miraculous vent brushes to reach inside) is synonymous only removing the "tip from an iceberg".
If you are fairly confident in using some basic hand tools. I can almost guarantee that if you disconnect the dryer's power cord from the wall and remove the vent hose from the back, you are at the beginning point of removing ALL the lint from the dryer. Use a hex nut driver or a screwdriver to remove the screws from the back of the dryer to inspect the area where the exhaust chute is that leads to the area where the vent hose is connected. (Be sure to "count" the number of screws and put them into a tin can or other retaining device to keep from losing any of them). You should be able to see the entire compartment once you open it. Carefully loosen the screws holding the exhaust chute as you will probably find plenty of hidden lint inside. Don't be surprised to find enough lint inside including the blower wheel to fill an average plastic grocery bag! Many dryer fires start in this area because most people do not know that so much lint collects there. I highly recommend that this easily accomplished task is done about one a year to keep the exhaust chute clean. It only takes about an hour to do the job very completely. Use a flashlight to inspect the entire area. You will be able to see the heating element inside the exhaust chute. If there is a broken heating element inside, the heating element will have a "break" in the wire. There is also a thermostat attached to the chute. Be sure to mark any wires inside before disconnecting them. Once you put the exhaust chute back together, test it again. If the dryer still does not heat, (and the heating element is not broken), the thermostat could be bad. Performing this inspection once a year is also good fire prevention maintenance. I am very curious about how much lint you find and if this fixed your problem. Please send me a reply. Thank You!
Jan 02, 2014 | Whirlpool LER5636P Electric Dryer
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Hi I have a whirlpool gas dryer and it heats up when you 1st start it up but after a while it runs cool. Also the timer does not advance so it just runs aimlessly. I already cleaned the vent and lint chute...
The timer is the Principal initiator of the entire heating cycle. it authorizes the needed current for proper element functions. you have stated that the timer fails to advance, or rotate properly. this will cause inadequate heating, therefore, not allowing optimal dryer performance.
replacing the timer will fix this issue.
((I would also like to recommend replacing the running thermostat as well. this is good preventive maintenance. its located on the dryer blower housing or vent duct.))
Sep 02, 2009 | Dryers
Vent was cloged with a birds nest now it wont heat
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Whirlpool Slimtwin gas dryer does not get hot but does tumble
Most likely it is the heating element, Unplug it, take the back off and you can see if it is bad
Jul 17, 2017 | Whirlpool LGR7646E Dryer
Dryers Logo
160 people viewed this question
Top Dryers Experts
