There are a couple to possibilities. Either the Evaporator coil is iced over or the fan is not circulating air. All of the cold air comes from the freezer if no air circulates the refigerator will not get cold. check to see if the evap coil is frozen over. If it is deforst it with a hair dryer. for continuity with an ohm meter if it is open replace the heater if not check the defrost thermostat. If it is open replace it. If not replace either the defrost board of the defrost timer depending on which it has. If it is the fan not working check for voltage going to the fan. If you don't have any replace the defrost timer.
My GE refrigerator is getting too cold and freezing items in bottom of refrigerator and toward the...
(More)
My GE refrigerator is getting too cold and freezing items in bottom of refrigerator and toward the back of the refrigerator and freezer not getting very cold. Freezer is on top.
Freezer working good. Frige not cold. The cold setting for frige not lit up. When I turn frige cold...
(More)
Freezer working good. Frige not cold. The cold setting for frige not lit up. When I turn frige cold seting down it does turn off & when turned up you can hear it running . set at cooldest setting & still not very cold.
hi, i defrosted fridge the other day all was fine when i plug it back in a few hour went by and it...
(More)
hi, i defrosted fridge the other day all was fine when i plug it back in a few hour went by and it stopped working now it keep trying to kick on an then off it is an older model but i dont think it needs to be trashed yet?
My GE refrigerator freezes meat and ice cream but not ice cream. The warranty has expired. Has...
(More)
My GE refrigerator freezes meat and ice cream but not ice cream. The warranty has expired. Has anyone else experienced this problem and/or has a solution. Thanks.
