Question about Sony (PCWA-C100) 802.11b Wireless Adapter
Vaio wireless lan not working, but Ethernet cable works,
All, The WLAN worked fine , now it won't connect, not sure what happended, can you guys point me to what I should check ?. The LAN cable works ok
  • 7 more comments
  • Anonymous Mar 05, 2008
    adsdsdqdw
  • Anonymous Mar 06, 2008
    I hav e thesame oprblwm
  • Anonymous May 09, 2008
    My VAIO says it connects and I get an indication saying that I am connected and have a strong signal...but I can't access Interneet, skype etc.. I access internet perfectly with lan cable to my router (d-link di 624)
    thanks if anyone can help.
  • magiting May 17, 2008
    im connected with my WLAN outside my room and can install anything but when I use my LAN I could only access my internet but I could not download or upload anything to the net....what is the problem? Im using Asus F5V intel core 2 duo, 2GB ram, OS-vista ultimate...im using radeon x2300
  • Anonymous Jun 18, 2008
    my wireless lan does not trun on.
  • Anonymous Mar 02, 2009
    I also have the same problem. The wireless lan switch is on, but the connection doesn't work and the computer says that the switch is not on. The light doesn't work either.
  • Anonymous Apr 07, 2009
    same!
  • lindsayAsh May 16, 2009
    On my VGN-NR21J running Vista, the wireless switch doesnt seem to do anything at all. I can turn it on/off and vista always says the wireless is turned off...
    Anyone know why this is?
  • MYRTIS DIGHTMAN Oct 06, 2012
    CAN NOT CONNECT TO WIRELESS ITS LIKE THE POWER SWITCH IS ON BUT WILL NOT
Most of the times in your right lower corner there is an icon that looks like two arrows pointing diffrent dirrection....the name of this one is vaio smart utility..let enabled the wlan box and then try to connect it
Posted on Sep 22, 2008
The above solutions may work for some, but my fix was MUCH easier!!
I had this problem this week of no wireless networks being detected after having a Vaio VGN-C series for over three years now. I never had this problem before, but my toddler hit some keys on the computer one day and the next day my wireless internet wouldn't detect anything. There are several different posts online on how to fix it, including redownloading drivers, or simply turning the switch on on the front or side of your computer.
The real answer is [B][U]MUCH EASIER[/U][/B]! For some reason, Vaio put this link in the quick launch bar on the bottom right of your screen (You know all those anoying little things that you never use!?! :confused:). Just click on the green box that has LAN in small print and check the box for wireless internet and you are good to go. There was no need to restart the computer or anything. I looked forever trying to find a solution to this and it is a simple fix. I hope this helps someone else out there who got as frustrated as me about this weird feature. :D
Here is a screen shot of what it looks like on my Vaio VGN-C190G:
[IMG]http://i40.tinypic.com/2pyqkp4.jpg[/IMG]
Posted on Apr 09, 2010
Solution #1 said to look for two arrows pointing different ways. I couldn't find this on my Sony Vaio VGN-C190G, but instead a little icon in the bottome right that is a small green square and in very very small writing on the bottom of the square it says LAN. When I double clicked on it, it opened up a small menu with 2.4GHz and 5GHz Wireless LAN as options. I had 5 checked, and switched it to 2.4GHZ Wireless LAN and BINGO...it worked! This has been bugging me forever. My switch was on, and my drivers were all updated...but it still wouldn't work. All is back to new now!!
Posted on Feb 01, 2010
Aug 18, 2008- have solution to my problem finally i hade to disable wireless swithch setting utility on my vaio there was some sort of conflict. this can be done by start-all programs-acessorys-system tools-task sedualar. scroll down to wuss and stop it then disable it by double clicking and reboot. ~where the hell is wuss?! O.O
Posted on Sep 12, 2009
Windows will not detect any wireless network connections.they are displaying their ssid and other laptops can detect them in the house.i can connect throuch enternet cable .i have installed several differnt driver versions for the mini pci card and device is working properly in device manager.the green wlan light comes on when i boot the laptop along with the bluetooth light however as soon as vista fully loads the light wlan light goes off but the bluetooth light stays on.it says radio is disabled for the device when i cick enable it says radio still disabled slide switch to on however it is already on.i have WLAN AutoConfig set to automatic and is started. the device is working i have booted up a version of lynux from cd and can detect networks and connect to them but vista wont even detect them. also i cannot open wireless switch settings in vaio control center when i click it nothing happens but other icons do open. have went into windows mobility center wlan connection is there but the option to enable it is greyed out.i have also run a full anti virus check with northon.
Posted on Aug 17, 2008
  • Mike Mullet Aug 18, 2008
I tried all suggestion above.
- Change the LAN greenbox in task bar to 2.4G --
Posted on Aug 31, 2010
"if I turn on the laptop with the wireless switch in the off position, then turn it on after Windows (XP Pro) has finished booting, then wireless works fine (connects, etc)..."
http://forum.notebookreview.com/archive/index.php/t-76522.html
Posted on Aug 28, 2008
Http://forum.notebookreview.com/archive/index.php/t-76522.html
"...if I turn on the laptop with the wireless switch in the off position,then turn it on after Windows (XP Pro) has finished booting, thenwireless works fine (connects, etc)..."
worked for me!!
I have the same problem. My wireless lan switch is on, but the computer is saying that i need to turn it on. The light is also not flashing.
Posted on Jul 01, 2008
1. Drain battery completely
2. Connect to A/C power source
3. Boot up, log on and left click on internet connection in system tray
4. Select diagnose and repair
5. Follow directions that appear.
Posted on Dec 27, 2009
Hi people I have an airlive radio the power and wlan led are working whith the indicator of the wlan blinking but the Lan indicator light is off i have no wired connection to my computer.
The failure lies on the LAN side. You need to check back towards the server, somewhere there is a disconnection.
Does it supply Power Over Ethernet?
The radio only provides access to the server/router over the LAN.
If it cannot log on to the LAN it will not work.
Feb 22, 2015 | Computers & Internet
Wireless lan won't work on sony vaio vcg-rb43 after disk restore
Go to Windows Updates and see if there is an update their sometimes that happens with drivers. Start there Updates and install all the updates hardware updates as well. If that does not assist you there may be a fix at the Sony Vaio support drivers and download for your driver start there. I would download the driver online for the wireless software. Click Here to go to the driver site enter your model and info they request and download whatever you need from there. This should get you up and running again. I hope that this assisted you. Note download the Network anything that has to do with wireless Lan John
Apr 19, 2012 | Sony VAIO VGC-RB34G PC Desktop
Using linksys wet11 to connect to internet through linksys wireless router, working before, suddenly, not working, trying to setup again using static IP, not working, using DHCP, not working, run...
it's because you need to change the ipaddress in you linksys
make sure the ipaddress from you modem it's not 192.168.1.1
if you have the same ipaddress on the modem try changin the ipaddress on the linksys to 192.168.1.1
Oct 15, 2009 | Linksys 802.11b Wireless Ethernet Bridge:...
I have a dwl-2000ap, the problem on the lan port does not function, led indicator lan does not work. I have input cable type Straight-Through or crossover, but it still does not function whether dwl-2000ap...
It should work with either cable. The LED will only come on when a connection is made to the computer or router. Is the LAN adaptor working correctly at the other end.
Jul 19, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Wireless network connection problem
Ok with a peripheral on USB or on PC card bay you can try to connect to a Wireless lan:
Please check this tip on the subject
To connect to an existing WLAN you must be sure your wireless card is working: I assume you installed all the related sw coming with the wlan card.
Using the card installed driver check card is enabled and running (in Control Panel/Network connection should be visible and enabled)
Then you can connect to an open Wi-Fi HOTSPOT or to your WLAN you configure with a router connected to your internet modem.
  1. To connect to an existing HOTSPOT: find a location where you know a wi-fi access point (HOTSPOT) is active: Internet cafe,, library, airport,, station, hotel etc.your card should be able to find the existing network when you select "show existing network" in wlan driver. Connect if network is "unsecure" (= no password or key is required) or ask for password if you can get it for a fee (hotel)
  2. To connect to your home or office WLAN be sure to use a router (or access point) with same standard of your card (802-11G or B or A or N) with same security protocol (WEP or WPA) and configure your router Internet access BEFORE wireless access. Connect your PC to your router using a LAN cable and be sure you can browse through the router.(contact your ISP for router specs if you need it: PPOA/E and other). Follow the tip and your router doc for settings
Jan 14, 2009 | HP Compaq Evo n610c Notebook
Does not operate
Be sure you can browse internet using wired LAN
Connect to Router using LAN cable and configure it.
Enable Radio and set security protocol.compatible with your PC wlan card.
Jan 09, 2009 | Linksys Wireless-G WET54G 802.11g/b...
Router problems
Check with this tip.
Check if router is working on Net using a Lan cable to connect your PCs and check if you can browse from PC..
If Internet OK check if radio is enabled in your Belkin router.
Then check if your SSID broadcast is enabled in your router.
Check if Router and PCI Wlan adapter are on same WLAN standard A,B, G, or N and disable every security protocol (WEP or WPA)
Define a new SSID name and check if you see your Wlan on PC.
Restore your security as soon as connection established.
Jan 05, 2009 | Intel PRO/Wireless 5000 LAN Access Point...
No power led, wlan led blinking
well, what you could try is unplugging the power source from the cable modem, and the router. wait about 1 minute. then plug everything back in and wait.
i remember having this problem as well, but i think the problem with me was that my wireless computer was too far away from the wireless router, not saying that your too far or not, but that what i had, so i just pitched the wireless adapter, and created an ethernet connection. just sharing my experience.
Feb 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
Netgear WG602 wireless router, Connection Local only !
What I think is you unplgged them at the wrong times.
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Now tell me the errors, like if it says connection limited,etc...
Thanks,
Cam
Oct 18, 2007 | NetGear WG602 802.11g/b Wireless Access...
Sony (PCWA-C100) 802.11b Wireless Adapter Logo
19,102 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
