Question about Panasonic PV-GS2 Mini DV Digital Camcorder
Resetting Problem While trying to rewind the Mini DV tape in the camcoder, the camcorder is always asking to press the reset switch. Why? Is there any resolution for this?
  • Rohit Goswam May 04, 2008
    Same "Push the reset button problem in panasonic gs 200 camera. i turned it upside down but it didnt worked out. its an expensive camera please please please tel me how to fix "Press the reset switch" problem
We have owned this camera since November of 2004. We had the same issue that you are having. We finally realized that the "press the reset switch" beep was more frequent when the battery was getting low, regardless of what we were doing with the camera. We usually got "the beep" when we would press record, but it would happen anytime, really. Eventually, we had the problem all the time. A quick trip to the camera shop solved the problem..we needed to buy a new battery.
Since we bought the new battery several months ago, we haven't had the problem since. The new battery was (I think) about $40. Don't buy one from the panasonic website...I couldn't believe what they wanted for the same battery...can anyone say rip off??
I'm not sure if my solution will help you, but that is how we solved our reset switch problem. Good luck to you!
Posted on Jan 13, 2008
  • Ozan Kucukyildiz Jul 08, 2011
    After I read this solution, suddenly realized my cam does same thing too. I mean when battery get low, this problem occurs.
My Sony handycam won't allow me to use the touch screen features in play mode. I can't rewind, play or fastforward the tape. It has reached the end of the tape - what now?
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Reinsert the tape and check the operation
Try another tape to check whether the issue persists only with particular tape.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
Note: In the above figure, 8 represents the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Dec 18, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
The tapes In my Panasonic PV-GS14 are stuck and won't run
you cannot move the spindles/cogs in a mini dv tape without pressing down a small lever on the rear of the cassette.
the lever is in the lower right, move the lever, then move the ribbon protector to the open position, then spin the cogs, the tape should be free.
if not, then you have a jamm inside the cassette, you can open these casettes by removing 4 small screws. ( this is a very fiddly job & you may ruin the casette, if you dont know how )
May 09, 2017 | Panasonic Palmcorder PV-GS14 Mini DV...
Tapes will not play
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
Oct 01, 2008 | Sony DCR-HC32E DV Digital Camcorder
Rewinding on jvc grd850
You might still be in the record mode. Try switching to playback mode.
Sep 24, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Trouble using dcr-trv6 mini dv camcorder
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Panasonic NVGS4 camcorder problem
Did you try with different tapes? light turr sound is always there in Rew/FF as the tape rotatets very fast. If the head motor stops while spinning, the error will be detected and the unit needs resetting. also if the head is sticky, tape gets stuck on head and unit will stop. Try to clean the head with head cleaner and check.
Feb 27, 2007 | Panasonic NV-GS40 Mini DV Digital...
JVC GR-DX307 Mini DV Digital Camcorder
preciso do programa da JVC GR-DX307 pra fazer o dow
Oct 03, 2006 | JVC GR-DX307 Mini DV Digital Camcorder
Panasonic PV-GS2 Mini DV Digital Camcorder Logo
559 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
