Table top belt
I have a Fisher tabletop record player, Model MT 6410. It is speeding up and slowing down a lot, and i think it needs a new belt. Can anyone recommend where these might be available?
Thanks!
Keith
  • 36 Answers
It looks like these cost a little less than $20 US, and are available at several websites and local specialty shops. One site that sells them is http://www.elexatelier.com/fisher.htm.
Posted on Jan 01, 2008
The speed on my turn table is too slow.
Hi. You need a new belt. If the belt is too loose it will slip. Try to take the wheel off and investigate. Put a little oil in/on the bearing as well. (2 and 1 oil).
If it is a direct drive you need to look at the electronics (motor and caps). You may need to take it to a shop for that if you are not a electronics expert. Good luck.
Feb 16, 2018 | The Audio Players & Recorders
Cassette tape will not play, just screeches, why
Without a make and model, the only suggestion I have is bad belts. Some players can require a lot of disassembly to get the new belts on. If you go to Turn Table Needles, they have a nice feature where you can enter your make and model number to see what belts you will need.
Dec 12, 2017 | Audio Players & Recorders
The turntable is not revolving at the correct speed slowing the record down
Sounds to me like your belt is streched. Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Crosley CR49-TW Tweed Traveler Turntable...
Rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
May 26, 2009 | RCA 200-Watt 5-CD Compact System Model...
Slow turntable
Most older models had a rubber belt that will deteriorate over the years and if you cannot find one search in "O" rings at hardware store for correct size.
Feb 24, 2018 | Emerson MS9920TTR Shelf System
Fisher Studio-Standard Belt-drive Semi-Automatic Turntable MT-32
Most likely the grease in the whole system has started to stiffen or the motor is failing. This can be fixed. Try oiling the motor first. If that fails, I'd look at the motor driver IC as the most likely failing part.
Dan
May 22, 2008 | Audio Players & Recorders
Philips Gramophone record player repair
which model you have? 242? Philips truntables can be easily repaired only if you know where to take them for repairs. I am also living in bangalore.. and I am a vinyl, retro turntable collecter. just send me you phone # at redlag@gmail.com. I will be glad to guide you on this... cheers
May 15, 2008 | Audio Players & Recorders
Fisher turntable mt 6410 removal
Look at spindle bearing in center of t-table. There is probably a small ring lock there holding the table. Use a pick or small screw driver to carefully remove this ring.
May 07, 2008 | Audio Players & Recorders
116 people viewed this question
 Grubhead
Grubhead
