Freezer won't close on one side because teeth on wheel are off. It must have gotten off when freezer was opened. I can't figure out how to get teeth back in right place... any suggestions?
Take the drawer all the way out and put it back in. Towards the back of the freezer the wheels are released from the track. Withe the drawer off of the tracks out will be much easier to get it back in alignment. Also check for ice buildup on the teeth as this is a common cause of this problem
Everything seems to be working OK except mosture is accumulating and freezing in the refrigerator...
(More)
Everything seems to be working OK except mosture is accumulating and freezing in the refrigerator side on the side next to the freezer. I've checked door seals and they seem to be fine. Temperature settings are set per the manual.
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker....
(More)
I have a Jenn Air side by side fridge. Recently, I had to replace the ice maker. Installed it a week ago, and everything seemed fine. Today, it has started discharging water out the water dispenser when the ice maker is going through it's fill cycle. I get some water in the ice tray, and also water spraying out the water dispenser onto the floor. HELP!
Very similar situation where the water dispenser located on inside left side of frig, drips somewhat slowly (around one-two drops every five seconds), but essentially pours out when the ice-maker fills with water.
