Question about T-Mobile Wing™ Smartphone
Button stuck? My T-mobile Wing keeps scrolling uncontrolably on its own and won't stop. It will stop a little when I push a button on the phone, but will not if I touch the screen. It is also making my backlight stay on so I always have to keep my phone charged. It is like the round button on the bottom is stuck holding down. Does anyone have any idea on what I can do? Please help!
  • Anonymous May 04, 2008
    i have the same problem, my left or right circle button will just bugg out and keep scrolling uncontrollably is there anything to do that can stop this??
  • 97 Answers
Or course, powercycle....if that doesnt work, a master reset will be needed.....because it sounds like there might be somehitng stuck on the screen in the corner for make it scroll around, clean the screen with a qtip and rubbing alchohol.....if that doesnt work, try a software reset. with the phone off, you will have to press and hold the button withthe lines on them and press the power button.....release the powerbutton.....the phoen should turn on and go to a black screen with white writing....release the soft keys here and press the green call button...it will reset the phone, but in turn, you will loose your info that is not stored on the sim or media card...
this is hard to do, so if you can navigate through the phone go to start, setttings, system, clear storage. it does the same thing. good luck :)
Posted on Jan 01, 2008
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
At power up, tv scrolls uncontrolably through channels, power light flickers
1. Take remote control far away from tv - 3rd or fourth room. Then switch on tv. If uncontrollable scrolling stops , then cause may be remote button (Ch+ or Ch-) has got dirt inside and its shorting.
2. If taking remote far away doesn't stop scrolling then (Ch+ or Ch-) button on front pannel has shorted. Take a cutter plier and care fully remove button from its circuit board. ( If you know desoldering, it is far better than cutting). If scrolling stops then you can operate channel change with remote.
Jan 27, 2014 | Samsung LN46C600F3FXZA 46in Lcd Tv 1080p...
My cherry mobile nova android phone keeps on powering on and off every 5-15 seconds, what should i do to stop it? i can not use my phone because it will keeps on restarting
Your phone is stuck in a "Boot Loop". This was most likely caused by a newly installed update, program or an unfortunate virus. Start by removing the battery for about 30 seconds. Push down on the power button while the battery is out, to release all memory from the board. Re-install the battery and turn the phone back on. If it is still stuck in the boot loop, you will need to perform a master reset.
WARNING!!! A MASTER RESET ERASES ALL DATA ON THE PHONE AND RETURNS IT TO THE ORIGINAL FACTORY SETTINGS!
PROCEED AT YOUR OWN RISK!
Master Reset for your device is done by turning off the phone. Then press and hold the camera button + volume up + power button. Keep holding even when the phone turns on. Navigate with the trackball, scroll down and click on Wipe data/factory reset. Hit yes to confirm everything and let her rip.
Dec 20, 2011 | HTC G1 Cell Phones
My wing work fine when its on but it is hard to turn on i allway have to play with the button but now it just stop workin for me
spray some WD40 onto the affected button, and make sure the battery is removed and phone is OFF. After u spray WD40, push the button gently until the sprayed solution evaporates. Good luck.
Jan 05, 2011 | T-Mobile Wing™ Smartphone
My wing t-mobile display was locked. And what
You need to do a hard-reset. This will erase your added content (third party programs stored in phone memory, notes store in phone memory, etc.)
You must press the reset button while pressing the left and right soft-buttons at the same time. You need your stylus or something small enough to press the recessed button next to the volume control. Once you press the reset button, keep holding the soft buttons it is reset. The display lock should be gone... as well as everything else you put on it.
Hope this helps,
Bill
Mar 27, 2010 | T-Mobile Wing™ Smartphone
The most common cause of the problem is a stuck/shorted button either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control battery or put it away from the television. Press the menu button on the television and check if the menu scrolls by itself. If yes, the DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Jan 16, 2010 | Haier HP42BB 42 in. Plasma TV
My 6500s non stop scrolling
I think the scrolling button has been stuck. Call and enjineer. Or you yourself open case and chek.
Aug 17, 2009 | Nokia 6500 Slide Cellular Phone
Motorola V3 Razor
take it to a mobile service center and have the flexcable replaced or the flash the flexfile on the phone.
if that does not work then relfash the firmware on the phone
Mar 02, 2008 | Motorola Mobility RAZR V3
Tmobile Wing won't stop scrolling
Could be the touch screen, fold a piece of paper in half and run it around the screen and make sure nothing is under the lip.
Dec 13, 2007 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
107 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
