Router connections I have Dlink router in 2 different homes and I connect to them through my Dell laptop. In home 1, in other cities, and with unknown location routers in home 1 I can connect fine.  I get good signal strength and I can connect to the outside through Firefox. In home 2 in can connect through unknown location routers and I can connect to the router in home 2. (Connection defined as having good signal strength and speed.) However, in home 2 I can not get outside through Firefox. I keep getting "poor or limited connection quality" because the computer cannot get an IP address assigned to it automatically. I have windows defender runnig all the time and I have not changed any settings between Homes or when I can get on routers that allow me to connect.  I have tried resetting the router seveal times but I cannot get it to stay connected.  I am also using a wireless booster to extend the wireless range in the house.  It has two lights on it to display the status.  For some reason the light that indicates it is connected to the router drops out every now and then.  I am trying to connect when the system is up and normal.  I don't think this has anything to do with the problem but I thought I'd mention it. There is also another wireless laptop on home 2 that is operating next to the router without any problems. I'm not sure where to look given all the conditions I mentioned.  I would appreciate any help possible.  Thanks. Please respond to
  • 61 Answers
If you have a laptop in home 2 that is able to connect with NO issues whatso ever I would almost think its a security issue... Do you use the same kind of encryption on both home 1 and 2? (ie WPA or WEP)
Posted on Dec 31, 2007
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual:
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
Dec 11, 2010 | D-Link Computers & Internet
I have used this router for 2 years inone home attached by cable to a desktop and at the same time set up for wireless for other laptops in the home. I have got a new router for that house, but want to use...
1. Yes, clear the router for the new house.
follow these instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 03, 2010 | D-Link DSL-G604T Wireless Router
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router ( user name "admin
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Westell 327 router not connecting to my new Dell Laptop
So you having problem issue on the wireless router?
Try this:
1. See the icons on the down-right.
2. There'll icon with wireless connection.
3. Try to refresh it, and you'll detect you Westell router.
4. Click it twice, and you'll get connected to your wireless router.
Hope this help! Pm me if there's any questions =]
Jul 07, 2009 | Westell Wirespeed VersaLink...
Adding laptop to home system through Belkin59G .
basically your laptop cannot connect to the router this can be caused by a few things.1 is that your not set up on dhcp, 2 router is not set to give out i.p auto might be in static,3 could be a bad wireless signal
Feb 10, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
