The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
To program your remote by entering a code, follow these steps:
Turn on your TV.
Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
Press the TV button on the remote so that the LED blinks once and then remains solid red.
Enter the first set of 3-digit codes from the list. The LED will
blink once every keypress. After the 3rd digit, the red LED will turn
off indicating that the code was recognized for the device. If the code
was not compatible, the LED will flash several times and you need to
return to step 2 to try that code again or to try the next code in the
list.
After the LED has turned off, aim the remote at the TV and press
ON/OFF. If the device turns off, you have used the correct code and the
remote was successfully programed. If the device does not power off,
return to step 2 and try again with the next code in the list.
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
Turn on your cable box.
Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
Press the ON/OFF button slowly and repeatedly until
the cable box turns off. The LED will blink once each time you press the
ON/OFF button.
Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at [email protected].
