I got this error message when I startup my laptop ------------------ SMART Failure Predicted on Hard Disk 0: TOSHIBA MK6025GAS-(PM)
WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent
Press F1 to Contiune ------------------
The question is do I really need to replace another Hard disk since it still working fine or are there any way that I can fix this problem? And what causes this problem?
Thanks ! smart failare predicted on hard disk 0: wdc wd800bevs-22rst0-(s1) warning: immediately back-up your data and replace your hard disk drive.a failare may be imminent .
i got same error with hp a300n every time i start my pc it said<warning smart failure predicted on primary master samsung sv0411n a failure may be imminent press f1 for set up, f2 to continue>
then few days later the pc will crash and i have to format every time.-   akfa2
It is highly unlikely that you will be able to fix this since it's a hardware problem on the hard drive. The drive may last for years or it may die tomorrow. At a minimum I would back up everything you care about on a regular basis.
If you found this information helpful I would appreciate it if you would rate this solution. I hate to beg, but over half of the solutions I've posted have no feedback. I'm not paid for this I'm just trying to help.
I don't whether the built in microphone has indicator light, because the motion eye have it. another...
(More)
I don't whether the built in microphone has indicator light, because the motion eye have it. another issue is when I am using yahoo voice call, I can hear the caller but they don't hear me.
