Singing bird clock
I have bought my mum a national trust singing bird clock for christmas and it makes a different chime every hour and she wanted to see what each one did, but it has messed up the sequence of the birds and we have now lost the instructios, do you know how to sort it, i know its a quite random questin. thanks x
Take batteries out set clock to 12.50 pm then insert batteries and set to normal time. this will then put correct bird sounds with relevant bird.
Posted on Jan 24, 2008
I don't know if this will work with your clock, but on a version of the singing bird clock sold 10+ years ago, the sequence could get out of sync (when the batteries were low or had been replaced. I would have to wait until the hour of came up for a bird I could easily identify - an owl at noon for instance - then push a button on the back of the clock to play all the songs until the "hoo hoo hoo" came up.
Posted on Jun 28, 2008
HI there, you could try moving the hands to the hour of one of the birds that you know, then push the re-set button on the back until you get to this sound. Leave it for an hour to check that it is all working well, then change the time. Otherwise, take out the batteries, set time to 12.50, put batteries back in, then set time to correct time. Good luck.
Posted on Sep 16, 2008
There's only one battery visible and it doesn't sing. Where are the batteries for the sound?
It is located on the back side.
2 total batteries for this type of clock, one for the time piece the other for the audio portion.
I have a cool clock like yours, but mine is Corvette Engine sounds. Very Cool.
There is a small door with a screw.
Mar 15, 2015 | Audubon Society Audubon Singing Bird Clock
No sound
I found mine was just making a clicking sound and no birds singing. changed batteries,all that synchronizing birds to time and nothing worked. Remove screws holding back on that are located around the ring area. carefully remove the glass,the hands, then the holding nut for the motor housing, remove face from clock assembly.There will be a wire going to the eye sensor for daylight/nighttime. Take a paperclip and jump the two solder points where the blue/black and yellow wire connect to the little circuit board (must have batteries in) and this resets the song feature. Not sure why this works, Simply reverse disassembly procedure making sure clock hands are unobstructed with each other and not bent, dont forget the seconds hand it's little and easy to forget to put back on.
Dec 08, 2013 | Audubon Society Audubon Singing Bird Clock
Birds will sing only when you push the red button
The contact in the time movement isn't closing on the hour.
Nov 04, 2013 | Audubon Society Audubon Singing Bird Clock
Our bird clock has started running fast, gaining about 17 minutes each day. Any idea how to fix this?
No fix, other than replacing the time movement, which is a switch movement that can be purchased at several different clock part supply stores, catalogs, or websites.
Jul 14, 2013 | Audubon Society Audubon Singing Bird Clock
Why does my owl hoot at 10 instead of 12?
SETTING THE TIME: ( Remove all batteries before setting)
1. Turn the hand set knob in the rear of the battery compartment clockwise or counter clockwise to read 10 minutes before 12:00 o'clock (11:50)
2. Insert three " AA" batteries into the battery compartment
3. Now turn the handset knob clockwise to adjust the desired time.
Note: Each time the set test button"red" is pressed, this sets the birds melodies to the next hours bird. If pressed, you must follow the instructions above to reset properly or you will not hear the correct melody with the correct bird.
I found this answer on another site: http://answers.yahoo.com/question/index?qid=20080115175404AAdL2Lw
Hope it helps!
Jan 19, 2013 | Audubon Society Audubon Singing Bird Clock
Can you give me math problem
You want a math problem? Here's one!
Say 10 birds are sitting & singing on the fence, and you take a pot shot a nailed one of them. How many birds do you think are still left sitting & singing on the fence?
Oct 05, 2010 | Mozilla Firefox
3,310 people viewed this question
 Grubhead
Grubhead
