Question about HP LaserJet 1022n Printer
Labels will not auto feed
HP 1022n Printer.... When I print lables I have to sit next to the printer and press the go button after every label is printed. A message pops up that says the printer is out of paper, but I have a whole stack of labels in the tray. I tried changing the settings for labels, but even then it would not auto feed. Plain paper is not a problem, only labels.
  • Calcartman May 09, 2008
    Currently having the same problem.
    Hp Laserjet 1022n, printing over the network, and it seems that anytime they want to print more than one page they have to hit the Go button. Here are the reports i have been recieving:
    if I print out page 1 of a document it goes though, if I want to print page 2 separately, I have to hit the go button.
    I still have yet to find out how to make the HP 1022n printer print multiple copies w/o having to press the "Go" button.
    I am new at this company and have found almost zero articles of the problem online. It seems the intended operation is to hit the Go button when changing media (labels to envelopes to normal paper); however it is occuring under almost all circumstances. I have yet to see the problem myself, however it has been documented since 9/2007.
    Anybody with a suggestion or solution that worked for them would be great; as HP has been completely helpless.
    President:
  • 2,072 Answers
Have you gone into your print driver and changes the settings there?
I am not sure with your inormation if you have changed the settings on the printer or in the driver.
What it sounds like is happening is that there is a mismatch between the printer and computer.
It may even be set so that it is looking for lables in a bypass tray.
Somewhere there is a mismatch in information as to where the labels are loaded.
Start at the driver properties page and confirm every step in your setup.
Posted on Dec 31, 2007
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
I'm printing labels on my printer. After each run, the printer prints out an hp advertisement page for buying supplies, etc. Almost like a test page. How can I delete this annoying and wasteful...
Try this:
But first print a configuration report.(contain IP address)
Configuration Report
Release GO after LED begins blinking.
Now:
Reset the factory default settings (cold reset)
Turning on the printer while pressing the GO and CANCEL JOB buttons restores the factory default settings.
1 Turn off the printer.
2 Press and hold the GO and CANCEL JOB buttons.
3 Turn the printer on and continue to press and hold the buttons until all three LEDs are blinking.
4 Release the buttons.
Jul 13, 2011 | HP LaserJet 1022n Printer
Feeding-problems
you need to calibrate. hold the feed button down intill it flashes 4 times in a row and the quickly let go. it will feed some labels to calibrate and should stop at the tear off. you also have to set label size in the driver to keep from losing calibration.
May 14, 2010 | Zebra TLP 3844-Z Thermal Label Printer
Paper feed problem
With that many labels I would replace the paper feed roller, RL1-0266-000, about $8.00
it will save you lots of headaches and a spare will fix it next time it happens.
Sep 01, 2009 | HP LaserJet 1022 Printer
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Dec 14, 2007 | Zebra Stripe S600 Thermal Label Printer
HP LaserJet 1022n Printer Logo
165 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
