Home | LG | GCC4522B CD-RW/DVD-ROM Combo Drive | I am having trouble bur...
LG GCC4522B CD-RW/DVD-ROM Combo Drive
Problem for LG GCC4522B CD-RW/DVD-ROM Combo Drive
I am having trouble burning
By gylmc on Oct 25, 2009
I am having trouble burning to a DVD-RW,it does not recognise the disc I have in the drive,it keeps asking for a DVD-R-RW, what is the solution, thanks , Graeme
Comments:
Oct 25, 2009
- Hi roniecon, thanks for your prompt reply, I cannot find a tools tab when I open the 'D' drive properties, it is also showing a full disc, even if it is a new one, or if there is not a disc in the drive, regards Graeme
Oct 25, 2009
- Hi marked, it seems to be OK with CD-R but not with DVD-RW, if this requires firmware upgrade how do I get it, thanks, Graeme
Oct 26, 2009
- Hi VinayT, still no go, where do I go from here.
Thanks Graeme
Solution #1
posted on Oct 25, 2009
Somewhat Helpful)
roniecon
Rank: Guru
Rating: 88%, 635 votes
Open up on start menu,and click on computer,then right click on properties on the d drive,look and see under tools,and check mark for dvd`s and not compressed.This would be under the d drive.This should clear things up.I hope this helps.If it does not ,down load this software,registry mechanic,it will fix the problem.
Was this helpful?
Yes
No
Solution #2
posted on Oct 26, 2009
Not Helpful)
VinayT
Rank: Wiz  LG Computer Accessories  Expert
Rating: 81%, 846 votes
Clean the read write head with a clean and soft cloth or a moisr cotton swab. The head is that shiney dot on the moving part on the tray when you open it.
Was this helpful?
Yes
No
Solution #3
Not Helpful)
marked
Rank: Guru  Computer Accessories  Expert
Rating: 86%, 922 votes
If you're only using a CDR ad that is not being detected by your drive try first using a DVDR so we can see if it will be working fine then if that one work the problem here is with the firmware of your media drive and you can do a firmware upgrade on it to correct the problem....
Comments:
Oct 26, 2009
- So this premium post was refunded and you decided to give us IA because there's no way I can continue to provide you the next step for your problem..........
Was this helpful?
Yes
No
Solution #4
Very Helpful)
Gort007
Rating: 89%, 460 votes
Graeme,
The LG GCC4522B CD-RW/DVD-ROM Combo Drive is NOT a DVD BURNER.
It is a "combo" drive, which means that it can only READ DVD+/- discs and READ/WRITE CD's.
There is no firmware upgrade or any other modification that can convert your combo drive to a DVD burner.
Was this helpful?
Yes
No
5 people thought this was helpful
Popular Solutions for LG GCC4522B CD-RW/DVD-ROM
Questions and Unsolved Problems for LG GCC4522B CD-RW/DVD-ROM
Do you recommend LG GCC4522B CD-RW/DVD-ROM Combo Drive?
Answer
Answer
it happen that it been reformat so file is gone i cannot use my dvd rom
Answer
Well my cd drive no longer works at all, when i load a cd or dvd in the drive works spins the cd and... (More)
Answer
My HL-DT-ST RW/DVD Gcc-4522B is not reading any discs (DVD or CD) it spins them and then nothing... (More)
Answer
hello computer kamusta na ha robotek at tech master at
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG GCC4522B CD-RW/DVD-ROM...:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14695
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
