Question about Sony PS-LX250 Turntable
Turntable speed The turntable will only play at 45rpm. The speed button seems to function correctly but regardless of the position I can only get the 45rpm speed.
    President:
  • 4,402 Answers
Most of these were belt driven, if that the case check to see if the lever is connected moving the belt to the slower pully
Posted on Jan 04, 2008
Turntable doesnt start till platter is in 45rpm position
If you look underneath the deck you will find that the arm is linked by leavers to switches that trigger the motor. Clearly the one that for LP's has become bent out of shape and no longer pushes on the switch. Or the switch itself has broken or become bent, making no contact with the motor.
Nov 07, 2015 | Audio Players & Recorders
Record play 45rpm
just buy a new unit if you ain't got friends to help you.... and45.
Or see how far your goes?
Jan 28, 2014 | Stanton T62 Turntable
Would changing the belt help as my turntable plays too fast.
A lot of turntables have two belt positions on each pulley. One for 33 and one for 45. I would check to make sure the belt hasn't slipped into the 45 position.
Jan 13, 2013 | Audio Players & Recorders
Technics SL B210 - New belt, but still "plays up" on 45rpm I bought and installed a new belt, which worked fine, but after a couple of months of not using it, I now find that I have to run the...
Do on thing Oppen the Turntable and replace the 5 electrolytic capacitor ( 330mfd 16V,3.3Mfd 25V, two 2.2mfd 25V and 47mfd25v )in the circuit board. Also try to replace the 2 Vriable resistor ( 2K and 5K) in the circuit board of which one is for setting the speed of 33.33 and another for 45 rpm. If you need the srevice manual then just get in to the following link. You have to wait for some time until you will get a notification that Get the manual.
Ajin
Service manual
Feb 27, 2012 | Technics Audio Players & Recorders
Do on thing Oppen the Turntable and replace the 5 electrolytic capacitor ( 330mfd 16V,3.3Mfd 25V, two 2.2mfd 25V and 47mfd25v )in the circuit board. Also try to replace the 2 Vriable resistor ( 2K and 5K) in the circuit board of which one is for setting the speed of 33.33 and another for 45 rpm. If you need the service manual then just get in to the following link. You have to wait for some time until you will get a notification that Get the manual.
Ajin
Service manual
Feb 27, 2012 | Technics SL-DZ1200 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My Sony PS-LX250H turntable will only spin at 45rpm. When i push the speed button for 33 it doesn't change. i also sometimes have to give the deck a little push to get it to spin.
I have the exact same problem for the same model. Only spins at 45 and I sometimes have to kick-start it. I tried de-activating the switch (so that it's not making a connection) and therefore in the 33 position but that does not help.
Dec 14, 2010 | Sony PS-LX250H Turntable
Akai Ap-003 belt drive turntable pitch problem
Hi!
Make shure that is a 50Hz turntable. If you connect a 60 Hz turntable in a 50 Hz system, the result is aprox 28 RPM in the 33 RPM position/
Dec 31, 2009 | Audio Players & Recorders
Turntable 45rpm speed has stopped working
Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
Oct 17, 2008 | Philips Audio Players & Recorders
Sony PS-LX250 Turntable Logo
212 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
