Question about Koutech Systems PC720 (IO-PC720) (IOPC720) Serial Adapter
Canon PC720 copier
Says ther's a paerjam, but there isn't. Any ideas?
  • RLME8529 Jan 28, 2009
    PC720 indicates a paper jam, but there isn't one. Unpluging it, removing all paper & replacing it and opening and closing top dosen't solve the problem.
Looking at the copier where the paper comes out of, there is a switch to open and close it. Pull up and look on the left side in the back. There is a little spring that comes off, or breaks, or the plastic that holds it on breaks. THIS CAN PAPER JAM THE MACHINE AND SEEM LIKE A MAJOR PROBLEM. ALL IT IS IS A LITTLE SPRING. Hope that is only your problem.
Posted on Aug 28, 2009
  • L Bostrom
    L Bostrom May 24, 2014
    Found a spring in the back left corner that was not attached on both ends. Pulled it out and a small plastic piece also came loose but does not appear to be broken. How do I replace the spring or reattach it?
    Problem Solver:
  • 17 Answers
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred
Open and check for any paper jam .Clear paper jam and press ONLINE
Posted on Dec 31, 2007
Canon NP6545 Error 0005, please help me... Tq B4
this is error for fixing web cleaning belt.call service for exchange of web.
BUT THIS IS OLD MODEL AND MAYBE THER ISN'T SPARE PARTS AVAILBLE ANYMORE.
THIS ERROR CAN BE RESETED IN SERVICE MODE, BUT IT IS COMPLICATED FOR YOU.(BECAUSE OF SERVICE TOOLS AND SKILLS )
Aug 20, 2011 | Canon NP 6545 Copier
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Canon PC720 Gear popped out
hello.
probably its the gear of the register roller near the contacts of he machine .
Oct 22, 2009 | Office Equipment & Supplies
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Paper will not feed on my Canon PC720 Copy machine
Hello sir; You just need to replace a paper pick up roller it shoulf take care your problem.
Sep 16, 2009 | Canon Office Equipment & Supplies
What does E2 mean when it appears on my PC720 Panasonic copier?
A E210 has to do with the scanner part of the copier. Is the lens moving OK on warm-up? Dose it move at all and what about the optic's do they move at all? I would need some more info on the problem.... I don't want to lead you on, that it is a easy fix... It is a fairly older copier.. It may not be worth repairing
Sep 09, 2008 | Office Equipment & Supplies
Replacing Canon PC720 Toner cartridge change
Not sure if you found this out yet.
The cartridge just slides out. When you lift the latch you will see the cartridge has lifted too. All you need to do is pull the cartridge toward you. It slides right out.
Jan 13, 2008 | Office Equipment & Supplies
Koutech Systems PC720 (IO-PC720) (IOPC720) Serial Adapter Logo
1,236 people viewed this question
Top Koutech Systems Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Koutech Systems Computer and Internet Expert? Answer questions, earn points and help others
