Back to:
Tags:
Eizo eClient 630L Network Terminal
Problems with the default settings
posted by grieche1207 on Dec 31, 2007
Hello There,
i have got an problem.Ok I turn the Client on an then will boot, thats ok
next Time he will start the Single Button Connect. I dont need that stuff. The next Step i will go with Alt+F4 to the Password manager.Ther are go in the Connection Managment.I press F2 then I need to go to the Security Settings.I dont come n the Settings.i need help to come there
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 06, 2008
Not Rated (0)
daverh
Rank:Wiz Wiz
Rating: 82%, 56 votes
I don't know that particular thin client workstation but from the sound of it. it's very similar to others I have worked with. I suspect that some configuration data has got corrupted. There is normally a way to reset the terminal to the factory default - I would suggest you try that & then set it up again. It's a nuisance but I often used to find that was the only way to deal with this kind of problem. To reset it this way: There is often a small button on the back of the device which you keep pressed in whilst powering it on; if not you'll need to check the manual.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problems with the default settings:
I don't want to Accept this solution
Can you Help with these Network Terminals problems?
Network Terminals
I had to install windows vista once yet wasnt able to make...
Network Terminals
I have Acer Aspire 3004Lc series Laptop. In my system CD,I...
Network Terminals
Vista and internet connection issue and email issue ...
Network Terminals
pls how can i connect my analogue phone to my computer...
Network Terminals
I would like to know if I can while hooked to my router...
Loading problems.
Repair Service
Find Network Terminal Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
