Question about Palm Tungsten T2 Handheld
Help i have a viser deluxe my computer will bot read the usb port on my computer when i plug cradle usb cord. it will read other hardware from that same usb slot
  • 59 Answers
Try this-
Open up your Device Manager.
In Xp I right click on My Computer and go to Properties.
In the window that pops up, go to Hardware, then Device Manager.
Connect your Palm and try syncing, at the bottom a Yellow Triangle with an exclamation point ! may appear. If it does, double click it.
You will need to reinstall the drivers.
Posted on Jan 04, 2008
How do I get the craddle to turn on
It depend of model of your cradle:
If cradle is without charge capability (suits CPT-8000), it get power from USB for internal logic and irda.
Cradles with charging capability ( two charging pin in cradle socket) need a powersupply to power both the charging of CTP-8001 and the internal logic/irda.
The driver need to be installed before connect the cradle to computers USB-port.
Mar 03, 2014 | CIPHERLAB 8000 Series Handheld Mobile...
When i ever i connect my blackberry 8100 to my pc it demands drivers, how can i get this solved
insert the disc that comes with the phone and run it. this should install all necessary drivers for you but if you dont have it, you can go online and search for the drivers.
Nov 05, 2010 | RIM BlackBerry Pearl 8100
How do i set up my psp to my pc i have no manual
First, you need a Micro-USB to USB cord (plug the Micro-USB end into the PSP, and the USB end into the PC's USB port). If you don't have one, you can get it from Ebay or Amazon, just search 'PSP Transfer Cord' or something like that. After you've plugged it in, put your PSP in 'USB Mode' and then your computer should say 'Found New Device' and then 'Installing New Hardware' overtop of an icon in the tray. After it's installed successfully, go to my computer, and click the letter of whatever port you plugged it into (i.e., 'Drive F'). You should see some folders saying 'MUSIC', 'PICTURES', 'VIDEO', etc.
***NOTE: If your computer doesn't do anything when you plug your PSP in USB Mode into it, try using another USB port, or try going to My Computer to see if it's already there.
Feb 16, 2010 | Sony PlayStation Portable (PSP) Console
I need to find out where I can get a driver for a Moultrie I40 trail camera to view photos on a laptop
hopefully you're using XP...easy solution....use the usb cord that came with the camera;plug into camera usb port;plug other end into usb port on pc/laptop;turn camera on..."found new hardware" wizard should pop up asking for cd with driver etc.;tell the wiz you want to choose driver from a list....a list of manufacturers will be on left/models on right...don't look, Moultrie ain't there, but GENERIC is...choose Generic;scroll down right column to find imaging devices;choose...a warning that it" may not be compatible...;ignor and choose...it will work and you'll get a prompt that hardware is ready to use...go to start/my computer/double click on drive id'd as "digital cam drive;MOULTRIE CAM, OR HOWEVER YOUR COMPUTER ID'S IT;a folder will pop up;double click;a sub-folder;double click,ect.,until you see the pics. Enjoy...
Ron L.
Oct 27, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
USB 2 PORTS NOT ALL WORKING properly on ASUS p5gdc-v deluxe
I thnik the Front USB ports are only Ver. 1.1. as to the ports at the back are ver. 2.O. so it does not read the external drive. this is hardware config. you might not be able to fix this.
Mar 24, 2009 | ASUS P5GDC-V Deluxe Motherboard
My Sony Cyber-Shot
Check camera USB cable carefuly, Use different USB port available in PC, Its also possible camera isn't install in its USB Cradle properly, Run Add Hardware Wizard from control panel and let Windows search it...hope these info help you out.
Aug 11, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Keyboard not functioning at all
The problem may be two things:
1) Its cord is disconnected from the PC unit
2) Your Keyboard drivers are outdated.
If the cord is fine, I recommend that you go to the hardware wizard (Start Menu -> Settings -> Control Panel -> Hardware Wizard) and run a "detect new hardware." This feature should be able to get your keyboard going again - and you should be able to access this feature by using your mouse only.
Aug 06, 2008 | Microsoft Natural Ergonomic 4000
Palm 515
Hi yes the plug into the cradle if this is fine then the firmware could have become corrupt due to virus or some data getting change this can happen.
The other thing you can try is remove all the software off the computer then plug the usb in and see if your computer tells you in a pop up box that new device has been found.
If it says this then the chances are its software of firmware problem ok.
If your computer dont give you pop up box telling you new device connected then the try another usb port to rule out the usb port being the problem or try a different device in the usb port to make sure its working fine.
If your computer dont pick the palm up then the problem is more likely to be hardware related like port on palm damaged or even internal parts failing inside the palm.
So just try plug it into usb port and see if your computer picks it up look under my computer and see if its listed their then let me know ok
Mar 27, 2008 | Palm m515 Handheld
PC restarts when VISOR put on USB cradle fro hot sychn operation
USB glitch is most likely, depending on which operating system you are using. This is especially common with USB hubs. If using a hub, try plugging the cradle directly to the computer. If still having a problem, unplug all USB then use Hardware Manager (in the Control Panel) to delete all USB entries. Restart the computer and plug one USB back in at a time. If this does not help, try the forums at www.brighthand.com.
Sep 07, 2005 | Palm Handspring Visor Platinum Handheld
Palm Tungsten T2 Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
