Microwave Ovens Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Magic Chef over-the-range microwave (MCO160UB), and recently the turntable and internal light stopped working while it runs. Light and fan underneath both work, and the internal light works when you open the door. The turntable and light will work on occasion. Any ideas?
Anonymous
Level 2:
Novelist:
  • Expert 127 Answers
  • Posted on Oct 25, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
127
Questions
0
Helped
44756
Points
448
Well an educated guess would be a short or loose connection in a common thats shared between the two that could rattle loose when it so chooses.. without a wiring diagram it would be hard to guess more specifically where without laying hands upon it.. and for that you'd have to lower it to the countertop level and dismantle to test.. it could always turn out to be a bad board also, but thats usually a done deal and doesn't repair itself then break again..
best of luck,
ttfn
1helpful
Magic Chef over-the-range microwave oven doesn't cook. Clock, inside lights and turntable are fine
If it lights up, the fuse is fine. On all of the recent Magic Chef's I've repaired, the magnetron has been the cause of the problem you described. Another possible common culprit is the high voltage rectifier.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
1helpful
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
MCO153UWT shutting down after 3.5 minutes
it is an internal fan that is the problems, if this is a counter top MW just replace it. if Over The Range (OTR) and under warranty call for service. if out of warranty replace.
I have a Magic Chef microwave over the range (Model: MCO160ub). It is about 2 1/2yrs old and recently it just shut down, the keypad does not operate.and nothing will come on. Previously, it had shut down...
If you could get it to reset by unplugging it I would suspect a problem with the main timer board. A blown fuse or bad connection wont reset by unplugging it. You would need to find a parts dealer who carris Magic Chef parts and give them your model number and ask for price and availability on the main PCB the printed circuit board
( timer board)
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
2answers
Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
2helpful
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
3answers
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
5helpful
4answers
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Top Magic Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Magic Microwave Oven Expert? Answer questions, earn points and help others
