Question about Refrigerators
Fridge fan compact refrigerator fan not turning.
  • 33 Answers
If fan is has seized and cannot spin freely then fan needs to be replaced
Posted on Jan 01, 2008
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
Why does my refrigerator turns off restart a couple days later ?
Could be the back of the freezer is not defrosting and is packed up with ice. The cold air then can't circulate to the fridge part as the fan is frozen solid in ice. Had this happen due to a faulty transducer that tells the defrost system the freezer is iced up and to go into defrost mode. Also it could be the fan that blows cold air down into the fridge from the freezer compartment.
Aug 24, 2014 | Haier HNDE03VS (32 cu ft) Compact...
My fridge wont stay cold.
it is not frost free , there is no fan , this fridge for light office use , also make sure gasket is ok , good luck:)
Sep 12, 2009 | Haier (B000194UBA) Compact Refrigerator
My GE Compact Fridge doesn't start up, even though I left it standing upright overnight and turned the temperature dail clockwise. Yes, it's plugged in. :)
Ok so I will assume from your post that you turned the dial completly to the coldest setting and that the compressor does not come on (nothing comes on, no fans no compressor). Did you just plug it in and attempted to start it ? There is usually a delay in starting your compressor, it should come on within 10-15 minutes - if not, try turning the dial back to off and then turn it back towards the coldest - do you hear any "clicking" where the dial is at (thermostat) ? If it does not start you may have a compressor relay problem or control board problem - But for your compact refrigerator I would say more likely a bad compressor or relay / capacitor, etc.
Sep 05, 2009 | GE Refrigerators
Whirlpool Compact Refrigerator w/ top freezer not cold enough in either compartment. Model: ETOWSRXMQO
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath or you may need freon
Aug 08, 2009 | Refrigerators
Honeywell compact fridge not cooling
Yes, listen to regular fridge for the sound of the compressor. do you hear it now? does it fill warm? Do you hear a clicking noise? Ifso, you'll need a potntial start relay, or a 3 in 1 start kit 15.00
Mar 01, 2009 | U-Line 15R Compact Refrigerator
Everthig in the fridge is freezing why?
possible stuck thermostat, defrost timer (if its a no-frost) or damaged freezer fan (if it has one) or shorted defrost thermostator element (if it's a no frost)
May 04, 2008 | MicroFridge MFR3S Compact Top Freezer...
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Avanti compact Refrigerator NOT COOLING
I had this same problem. I did some troubleshooting and figured out that the fan was being bogged down by ice. It wouldn't spin because the ice was so heavy. I turned the power off completely and let the ice melt. Once the ice was removed from the fan, the fridge began working again!
Feb 16, 2007 | Avanti EC15W-2 Compact Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
