Question about Canon LaserClass 7000 Plain Paper Fax
Black Copies I am getting either very dark or solid black copies. I have a relatively new toner cartridge which has worked fine up until now. What do I have to do to correct this problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Is there toner in the machine ? ( toner spill)
check the manual for the location of the glass, in the maintenance section, if it has toner on it copies will be black or dark, other wise the scaning glass is bad
http://www.retrevo.com/s/canon+7000+manual
Posted on Jan 02, 2008
SOURCE:
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
When copying the page comes out SOAKED in black ink
The cartridge or Toner is splitting out more ink.... Remove the cartridge Clean it and place it again.
Oct 30, 2012 | HP Office Equipment & Supplies
A toner catridge leaked in my Canon PC921. I cleaned it up and installed a new cartridge, but now my copies are dark on one side, light on the other.
on analogue copiers, if You have dark copies, that means that You need to clean optics ( mirrors and lenses - maybe some toner get to them ) or check/clean/replace the fixing film!
Regarding poor copy, clean/vacume/change the transfer roller ( beneath the drum unit - on paper path from drawer/bypass, before fixing unit ).
Hope that helps!
Apr 11, 2011 | Canon PC-921 Black and White Copier
Why are my copies coming out solid black, even though my exposure lamp is still working?
A couple of possibilities. Basically if your exposure lamp is coming on, the light is not getting all the way to the drum that is in the toner cartridge. It could be you have a mirror out of place. When the exposure lamp comes on, the light is reflected off the original and then off a series of mirrors until it gets to the drum. If one of the mirrirs has been knocked out of place, like due to a recent cleaning then that would cause black copies. The more common cause would be the drum protection "gate" that is on top of the toner cartridge is closed and thus blocking any light from getting to the drum. You can slide out the toner cartridge and look on top. There is a gate or panel that flips open to be able to see the drum. This gate must be opened when installing the toner. Also it is possible to have a bad cartridge but that rarely causes completely black copies.
Good Luck and Thank You for using Fixya.
Dec 06, 2010 | Canon PC-920 Black and White Copier
What causes a white streak and faded print to appear on copies?
Most often on the PC940 this means your toner cartridge is getting low on toner. To prove this is the cause, just remove the toner cartridge and while keeping it relatively level, shake it side to side a few times. This will re-distribute the remaining toner in the cartridge. Re-install and make a copy. The black streak/faded copy should be much better. If so then I would go ahead and get a new cartridge on the way.
Testimonials are always appreciated!
WheatlandServices
Oct 21, 2010 | Canon PC-940 Black and White Copier
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Copies have black streaks now
Dirt on the narrow glass will cause streaks through the Auto feeder, but copies should be clean if using the main contact glass if that's the case. Dirt/toner anywhere else (ie:laser optics) would cause light areas on the copies- not dark. Did this happen the very first time you used it, or shortly after? In other words, could it be coincidental? It sounds more to me, like the PCU (photoconductor/drum unit) needs replacement, or a fuser roller.
If cleaning the glass doesn't help, then one of these 2 things is causing your problem.
Apr 23, 2009 | Ricoh Aficio 450 Copier
Copies are very dark; almost grey
You need a service engineer to clean and service your copier.
Jan 18, 2009 | Office Equipment & Supplies
Xe80 copies coming out almost black on auto or light
Hello sir; Just replace drum cartridge it will take care your problem, GOOD LUCK!
Oct 30, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
130 people viewed this question
Clive
Clive
old marine
old marine
Ekse
