Question about Canon imageRUNNER C3170U Color Copier
I receiver error number E000067-0110
Once I turn on the copier, it loads then an error message shows up that says: "Shut down the machine and turn the power off and turn it back on. If you receive this message again contact your rep. Error Number: E000067-0110.
Let me know if anybody can help, I would appreciate it.
Thank you very much
George
  • 146 Answers
The error indicates a high voltage problem with the primary or transfer units. The most likely cause is the main drum being worn out.
This can be checked by going into service mode. You can do this by pressing the star button once, then press 2 and 8 at the same time, then the star button again. Now a word of warning. Do not change anything as it is very easy to turn your copier into a cabage!!! Press the tab marked COPIER, then the one called DISPLAY, next the one called MISC. You will see an item called DRUM LIFE, if it is 80 or more the drum will need replacing. Hope this helps.
Posted on Jan 02, 2008
What will i do after this process
Posted on Sep 02, 2011
In netflix/Movies refuse to load.error message
sounds like your internet is down . Id call your isp
May 19, 2014 | Apple Televison & Video
Initially the machine showed a fuser error. after opening the machine moving the fuser back and forth and restarting the machine did a self diagnostic and came back with the message - "machine error,...
Press menu, start, menu and the up arrow one at a time in order. Maintenance should appear in the display. Arrow down until you see 82 and then press the menu button. A machine error number should be displayed. After getting the number press the stop key to get it out of maintenance mode. The error that is displayed will determine the problem. What number do you see?
Jul 13, 2011 | Brother MFC-8660DN 5-in-1 Laser...
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Image runner c5870 error E0008-0001. How can i solve this problem?
that error happend because the last time the fixing assembly was rebuilt and or replaced the counter wasn't reset. what you need to do is go into service mode and clear the counter for the upper fixing roller and lower fixing roller.
to get into service mode you need to hit the additional functions key
the 2&8 at the same time
then the additional functions key again
this should get you in service mode even though there is an error code....if it doesn work the first time you try it shut the machine off and turn it back and try again. once into service mode
you need to hit the copier button....
then go across to the last tab .....counters...
click on it then click on drbl-1
then you will scroll down till you see
fx-up-rl click on it then hit the C button on the control panel where the numbers are and it should reset it back to 0
and then you need to click on
fx-lw-rl and do the same with it
fx-ex-rl and clear it as well
then you should be able to turn the machine on and off and it will come back to life
Jun 19, 2010 | Office Equipment & Supplies
Installed new staple cartridge; display showed message 'shut off/shut on'. I did that and now the copier won't power on.
Take the staple cart. out and power off and on. Mite have been a fluke but had and additional problem once you turn on the machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 17, 2010 | Konica Minolta Office Equipment & Supplies
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My HP Laptop suddenly started showing vertical stripes around once a week and could use it anymore until I turned it off. on rebooting, I would hear a couple of loud beeps but the PC will not boot....
There are a couple thing youcould have been looking at. number one a virus(trojan) got into you machine.
Number two you mother board is starting to go.
Number three your video card located on the mother board is gouing bad.
Number four you hard drive is getting weak
The fan on a laptop always runs to keep the machine cool. Smaller spaces get hotter faster.
I think based on your decription it was a virus, make sure you protected. Back up all ou info just incase it is the hard frive is startig to fail.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Oct 09, 2009 | HP Pavilion dv2700t Notebook
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
I receive an error E000013-0000
Check your toner waste bottle it may be full. Also the tube that transports the wast toner may be clogged. In which case its time to call a tech. John
Jul 02, 2007 | Canon imageRUNNER C3170U Color Copier
Canon imageRUNNER C3170U Color Copier Logo
1,400 people viewed this question
old marine
old marine
