My Maytage side by side has water dripping down in the freezer and it builts up with ice on the bottom. I took off the back panel inside the freezer and the drip pan under the coils was full of ice. I thawed it out but 4 days later water was coming out of it and forming ice on the bottom of the freezer again??
I believe there is more of a problem than the defrost heater is busted. This is a common problem when the defrost drain becomes blocked by ice and sludge. Here is a solution I believe leo2 should have a look at this possibility. Click Here=> Leaking Refrigerators Just What may be Haqppening And again Click Here=> Much more on this page=> Leaking Refrigerators! Every Refrigerator leaks differently so I want you to read over this information very carefully as not to miss something. You follow these examples of leaking refrigerators and I believe you problem will be solved. Let me know if this has been helpful, Thank You, Sea Breeze
The heating elements are busted need to replace.
i have the same problem. water builds up on bottom of freezer. I break it out every other day but it keeps coming back
how hard is this to replace?
