1998 ML320-- engine rotates but won't start
Spark plug -- located and how many
fuel pump and fuel filter located
I belive it's a timing chain not belt = 199km
  • John Ace Dec 31, 2007
    Yes its an SUV 1998 Mercedes Benz ML320. Request location on the above as mentioned.
    John Ace
    Guru:
  • 1,894 Answers
What product is yours?
say the company name with correct product code
Posted on Dec 31, 2007
  • 1 more comment
  • dewan nafees ahmed Dec 31, 2007
    please tell the problem in more detail
    u have posted the problem in thread containing doubts about printers.
    but yours is a car actually.
    anwyaws. say the problem in detail.
    AAM (all activity module) got CAN (controller area network) interruption signal to EIS (electronic ignition switch).
    immediately grab an AAM control unit.
  • dewan nafees ahmed Jan 01, 2008
    click here to get the parts you need
I have a 98 gmc 2500, w/ 454 engine.. Recently the engine was making some major noise so I took off the valve covers to find that the pushrods were very loose. I then dissected the truck taking off the...
Engine Cranks But Will Not Start Basic Checks:
A. Test Fuses. Test both under hood power distribution center and the fuse panel under dash. This is done with a test light tool. The test light should illuminate on both sides of the fuse, if not the fuse has failed and needs to be replaced.
B. Testing Fuel Pressure Test for proper fuel pressure with a test gauge on the fuel rail, most throttle body injection cars (TBI) are between 13 psi and 17 psi. and most (DPI) direct port inject systems are between 40 psi and 55 psi. If no or little fuel pressure is observed and there is 12 volt power present the fuel pump, the fuel pump needs replacing.
C. Checking Timing Belt Test for compression by removing a spark plug and insert a compression gauge. Crank the engine over about 5 seconds the gauge should read between 125 psi and 165 psi, if no compression is observed remove front engine cover to inspect timing belt or chain. Crank engine to observe cam rotation, if the cam does not rotate the timing belt or chain has failed. (note: if the timing belt drives the water pump it is best to replace the water pump at this time)
D. Test for Injector Pulse Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't respond, an ignition distributor/crank angle sensor (CKS) or an ignition module is most likely your problem.
E. Test for Ignition Spark Remove spark plug wire, insert an extra spark plug into end of wire, rest spark plug next to a ground source then crank engine. You should observe a blue spark between the spark plug gap and ground source. If no spark is observed, an ignition coil, ignition rotor or spark plug wires might have failed. (always keep hands away from engine when cranking)
The ENGINE CROSS-SECTION below (typical 'V-8' ENGINE) shows all main ENGINE components and indicates the exact location of the most HEAT DAMAGE PRONE PARTS - THE HEAD GASKETS.
Jul 18, 2008 | GMC Sierra 2500 Cars & Trucks
98 chevy blazer misfires when cold
what about the temperature sensor which is the one according to message given to ECU get the correct quantity of fuel ?
Aug 17, 2012 | 1998 Chevrolet Blazer
98 crv won't start
Check compression and timing belt. If belt is ok and you have compression, check to see if you have a pulse at the injectors. You use a device called a NOID light (basically a light bulb that plugs into the injector plug. Unplug the injectors one by one and plug the light in then crank the engine. Light should blink on and off if the system is working properly. If not check for a bad crank sensor, blown injector fuse and wiring harness. Hope this helps.
Nov 02, 2011 | 1998 Honda CR-V
The engine turnes but it wont start.
Free Auto Repair Advice by Professional Mechanics
Troubleshooting / Car Engine Cranks but Will Not Start / Engine Crank But Wont Start 2
* Why does my engine stall at idle?
* How do I change my spark plugs?
* Why does my engine stall?
* Why does the engine stall after replacing the battery?
* Why won't my engine crank over?
* How to retrieve trouble codes
* How to test fuel delivery system
* Engine cranks excessively
* Engine has excessive smoke
* Rapid ticking sounds when engine is cranked
* How to tune up your engine
* How to jump start your engine
* How to test an oxygen sensor
* How to open a car hood
* How a flywheel - flex plate works
For an engine to run, you need three things to happen inside the engine, compression, fuel and ignition, without any one of these components the engine will not run. Follow the repair guide below:
Engine Configuration with Camshaft Operation
Compression - Engine compression caused by crankshaft rotation and pistons moving up and down inside the engine block. If the timing belt or timing chain fails it will cause the camshaft to become out of correlation with the crankshaft or allow the camshaft to stop rotating. Either of these conditions will cause the engine to lose compression and sometimes cause internal engine damage.
Fuel Delivery System - The fuel system includes: fuel pump, fuel injectors, pressure regulator, fuel filter and pressure lines. This system is used to supply fuel under pressure to the fuel injection system, the lack of fuel pressure or volume will cause the fuel delivery system to fail and the engine to stall or not start.
Ignition Spark Delivery System - The ignition system components include: spark plugs, spark plug wires, distributor (if applicable), crankshaft angle sensor, camshaft angle sensor, ignition coil, ignition module, knock sensor and PCM (engine control module). The engine relies on the ignition spark to be delivered to the combustion camber at the correct time. If the ignition spark stops or is delivered at the wrong time the engine will not run or run poorly.
If your engine cranks but does not start follow this troubleshooting guide:
* Step 1 - Anytime you have a problem with electronically controlled components such as an engine, transmission, ABS brake, or SRS (supplemental restraint system, Air Bag) inspect all fuses using a test light and check the under hood power distribution center and under dash fuse panels. If all fuses test ok continue to the next step.
* Step 2 - To check for problems with electronically controlled components such as an engine, transmission, ABS brake, or SRS (supplemental restraint system, Air Bag) and the fuses test ok a trouble code scan is needed to identify any system trouble. Use a simple scanner tool to retrieve trouble codes and see if they relate to the specific problem, like a crank angle sensor failure code. If the trouble code present does not pertain to the immediate problem like an EVAP code ignore it until a later time, after the car is running. The reason we repair non-related codes after the engine is running is because sometime false codes can be triggered by the engine not running. Once the engine is running again the code present might cycle and turn itself off. You might say "if the engine doesn't run shouldn't it have a trouble code?" Sometimes conditions occur that will not be detected by the computer, example: if the fuel pump fails the computer cannot detect the failure, so the engine doesn't start and the computer thinks everything is ok with no codes. If no trouble codes are present proceed to the next step.
* Step 3 - The spark plugs in your engine are used to ignite the compressed fuel air mixture. If the condition of the spark plugs are fouled by excessive fuel or carbon the engine will not start, backfire or run rough. Remove all spark plugs to inspect their condition. Please use this spark plug condition reference guide to see how the spark plugs are operating.
* Step 4 - Determine if the engine has compression, this can be done a number of ways but the most complete method is to perform a compression check. Remove the spark plugs and perform a compression test on one cylinder. If one cylinder has compression then the remaining cylinders usually will be close to the same. Crank the engine over about 5 seconds, normal compression readings should be between 125 psi and 160 psi on each cylinder. If no or little compression exists additional tests will be needed. The most common reason for an engine to lose compression is a timing belt or timing chain failure. If low or no compression exists remove the oil fill cap and observe camshaft rotation when the engine is cranked over. If no rotation exists the timing belt or chain has failed. If your engine has a timing belt and you cannot see the camshaft easily remove the upper bolts to the timing cover and gain visual access to the belt, recheck cam rotation by cranking the engine over. Sometimes a timing belt or chain can jump causing the camshaft to lose correlation with the crankshaft and therefore causing low compression. The best test for this condition is to remove the timing belt/chain cover and inspect timing marks. If the compression is ok proceed to next step.
* Step 5 - Test the ignition system output, ignition systems can vary in configuration but operate on the same principal. Ignition systems can consist of a coil, pick up coil, crank angle sensor, cam angle sensor, spark plugs, spark plug wires, distributor cap, ignition rotor and a distributor and any variations of these components. An ignition coil is a voltage stepper coil that transforms a low voltage (12 volts) signal into tens of thousands of volts needed to jump the gap of the spark plug. This coil is activated by an ignition module triggered by using the camshaft/crankshaft angle sensor; timing is adjusted by the ECM (computer).
Hope helps (remember rated and comment this).
Aug 11, 2010 | 1999 Chevrolet Blazer
I have a 2001 chevy express 1500 v6 it wont start i check fuel pump,fuses and replaced distributor cap and rotor. havent check spark plugs or wires. it wont start...
Check for broken timing belt. Put a screew into spark plug head put the other end close but not touching to a metal engine part. have some one check for spark while you turn over engine. if thei is no spark check with distributor cap off if the rotor rotates when engine is being tuned over. if not then check timing chain. Good luck.
Jul 07, 2009 | 2001 Chevrolet Express
REplaced fuelpump , but it won`t start . I hear the fuel pump run and I was told the inline filter was replaced. So what is rong ?
Do you have a "no start" based on fuel, ignition, or engine problems? All of these are required to be good to start an engine. Must check for spark at plugs. If o/k check fuel pressure at fuel rail.If o/k check engine copression.
May 05, 2009 | 1993 Oldsmobile Cutlass Ciera
Cranks but wont start
For an engine to run, you need three things to happen inside the engine. Compression, fuel and ignition, without any one of these components the engine will not run.
Basic Checks:
Jul 14, 2008 | Hyundai Motor 2002 Sonata
Doesn't start
1. Test Fuses. Test both under hood power distribution center and the fuse panel under dash. This is done with a test light tool. The test light should illuminate on both sides of the fuse, if not the fuse has failed and needs to be replaced.
2.Testing Fuel Pressure Test for proper fuel pressure with a test gauge on the fuel rail, most throttle body injection cars (TBI) are between 13 psi and 17 psi. and most (DPI) direct port inject systems are between 40 psi and 55 psi. If no or little fuel pressure is observed and there is 12 volt power present the fuel pump, the fuel pump needs replacing.
3.Checking Timing Belt Test for compression by removing a spark plug and insert a compression gauge. Crank the engine over about 5 seconds the gauge should read between 125 psi and 165 psi, if no compression is observed remove front engine cover to inspect timing belt or chain. Crank engine to observe cam rotation, if the cam does not rotate the timing belt or chain has failed. (note: if the timing belt drives the water pump it is best to replace the water pump at this time)
4.Test for Injector Pulse Remove injector connector to insert injector test light (node) or volt meter. Observe light flash or gauge pulse while cranking. If light/voltmeter doesn't respond, an ignition distributor/crank angle sensor (CKS) or an ignition module is most likely your problem.
5.Test for Ignition Spark Remove spark plug wire, insert an extra spark plug into end of wire, rest spark plug next to a ground source then crank engine. You should observe a blue spark between the spark plug gap and ground source. If no spark is observed, an ignition coil, ignition rotor or spark plug wires might have failed. (always keep hands away from engine when cranking)
Jun 16, 2008 | 2000 Nissan Quest
386 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
