Question about Vizio L32 32 in. LCD HDTV
PIP I have a new Vizio and I cannot get Pip to work
  • Deezway Jan 08, 2008
    I have the same problem as Estevo. I have a new Vizio 32 in HDLCD but cannot get the PIP to work. I can access is but only receive a blue screen. When I choose PIP input it does not allow the option to choose TV. Placing an "x" next to the TV selection as if unavailable.
The reason is that your TV doesn't support the pip function it may be on the remote but check the manual look for the picture of the remote and it should tell you what buttons work or not
Posted on Jun 22, 2008
The solution is simple. It is a single tuner for PIP, only two sets can be run just not off the same tuner. TV/ AV1/ AV2, COMPONENT 1/ COMPONENT 2/ RGB, HDMI1/ HDMI2.
You can mix the signals ie: tv and compnent 1 or tv and hdmi1.
Not tv and av1as they utilize the same tuner.
Hope it helps.
Posted on Feb 05, 2008
Let me know what you find out, I have a similar problem. I can get the PIP screen to come up but it will not allow me to have it on an input that actually shows a picture - just blue screen.
junk@slaing.com
Posted on Jan 06, 2008
Does my vizio e series a-1 Tv have pip?
Hi
You do not give your exact model number so I couldn't look at the specific manual/users guide. I did look at one of the e-series guides and there was no mention of PIP (I presumed Picture in Picture and searched for several variations with no success). However if you go to the web page below, you will be able to find your exact model and then download the precise user guide and check it for PIP.
VIZIO Product Support and Services VIZIO
Good Luck
Nov 13, 2014 | Televison & Video
Only getting a small picture in left hand corner of screen
It sounds like you might be in the PIP mode. check your remote for the PIP (Picture in Picture) and go hit it several times the picture should move around on the screen one of them should be the OFF.
Sep 22, 2014 | Televison & Video
How to work pip in vizio tv
PIP or picture in picture works in two ways with the original remote--new sets with this actually have two tuners in them, one for main picture and one for PIP picture, you can change channels in both, swap the PIP to the main picture or even have both side by side.
Sure its got the PIP? what is brand and model number ?
Oct 30, 2012 | Televison & Video
Setup vizio vur103d pip
pip works mostly if you have cable tv the tv needs to use its tuner to display two channels.
Feb 11, 2012 | Vizio Televison & Video
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio sv420xvt pip
You have to be in 'TV' mode to access the parental settings option. Not sure why. When it asks for the code it's 0000
Jun 02, 2009 | Vizio GV42L 42 in. LCD Television
Cannot get pip function to work. i try to select pip and it says not available, but in my manual it says it is available. its really weird. it is even listed on my remote, but does not work when i push it....
Some models of the TV have PIP as an option, but not installed, and to make it cheaper, they use the same remote and menus, just disable the option, as it's not supported. Best to check the Manufacturer's website to make sure that it does do PIP, not that a related model which has the same user manual does PIP.
Mar 15, 2009 | Vizio VO47L 47 in. LCD TV
Vizio PIP second input source
Can you use a splitter somehow to make the cable be two inputs? That is all I can think of.
Jan 25, 2009 | Vizio L37 Television
Vizio sv420xvt pip
You have to go into the "Parental" settings and change the "Rating Enable" setting to off. Default password is 0000. The PIP will not work if your second source is fed into one of the AV inputs. It must be a composite or digital input. You should see the PIP menus once you change the Parental setting even if there is no other source turned on. This info is not in the book - had to call tech support.
Jan 11, 2009 | Vizio GV42L 42 in. LCD Television
Vizio VO32L & VO37L - PIP and Composite connection problems.
look in your owner's manual and you will see a list of input that can work with each other and ones that can't. If you don't have your service manual, you can go to vizio.com and get it there.
Jun 21, 2008 | Vizio L37 Television
Vizio L32 32 in. LCD HDTV Logo
368 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
