Question about Mag Innovision LT976S 19" Flat Panel LCD Monitor
Monitor problem i have a mag innovision monitor, it comes on for 1 sec. and goes off and in about 3 to 4 minutes come back on for 1 sec. and goes back out.
  • thomasprice Feb 17, 2009
    My monitor goes off after about 1 second also. You can shine a light and see that the data is still there but the lamps behind shutdown too quick making it unreadable. I am looking to see if there is a fix for this or if I have to trash the monitor.
  • Anonymous Mar 30, 2014
    what setting on a directtv remote do i use for a mag innovision monitor
My monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Posted on Jan 26, 2008
I am unable to get MAG Innovision 14" LCD monitor
You need laptop-type 12V, 2.5A (minimum) adapter plugged into back of VGA plug
Nov 13, 2010 | Mag Innovision lt456s 14" Flat Panel LCD...
Where to plug the power cord in the back of MAG TL765s Monitor
There should be another hole next to the speaker connections that says DC in, it goes in that hole.
Oct 29, 2009 | Mag Innovision InnoVision LT765 17" Flat...
Mag LT916s brghtness, contrst, phase off,, monitor stays on!
Sounds like bad caps in the inverter circuit affecting the ccfls.
Oct 05, 2009 | Mag Innovision InnoVision LT 765S 17" Flat...
Monitor problem
You need to figure out if the monitor is faulty or if it is due to the power in your house (not likely) or the fault of the computer.
  1. Try the monitor on other power jacks.
  2. Try the computer on other monitors and see if you get the same response.
If it seems to just be the monitor then you will most likely have to have it serviced or replaced. Is it still under warranty?
May 13, 2008 | Gateway FPD2275W LCD Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag lcd monitor
probably capacytor problem in the mainboard, take it to the lab it will be cheaper then buying new one
May 06, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
19 in lcd mag monitor
You need to try another monitor, any type. If you find another monitor does functions return the 19" monitor. Most monitors come with a 1 year warranty.
Feb 12, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Mag Innovision 765S Screen Flashes on and off.
It sounds like it is trying to re-synchronize it self and not going back the the default setting. Compare the resolution of the game to your monitor capabilities.
Jerome
Dec 29, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Open Questions:
Mag Innovision LT976S 19" Flat Panel LCD Monitor Logo
527 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
